Ski/Board Carrier Recommendations
Old Mar 3, 2023 | 08:40 AM
  #61
Kev M's Avatar
Originally Posted by yangpei
Do you know what set-up is lower profile - LR factory cross bars, Thule wing bars, or Thule bars with EVO kit?
I can't answer this question for you, but I can take some measurements of our set-up if you want.
I GOT the impression that the LR Factory bars we installed ARE made by Thule so they are probably the same as or very close to the WingBar Edge (though I got them SIGNIFICANTLY cheaper, like almost half the price that Thule lists on their website for the WingBar Edges for the Defender).
https://www.thule.com/en-us/roof-rac...AaAg2rEALw_wcB
Old Mar 3, 2023 | 09:42 AM
  #62
Dogpilot's Avatar
Yes most of the stuff on top of the Defender is re-badged Thule stuff. Personally, I got my bars for $90 each. Then again I shopped them off season in anticipation and got them on surplus sale. Bikein sold the mounts for significantly cheaper than other outlets, just don't be in a hurry for their shipping. Again, anticipation and off season is key. Even the Yakima Fat Cats were surplus Amazon stuff at ½ price, off season. Yeah, I'm cheap, mopped too many floors as a 'Beverly Hills Janitor' in university. UCLA was in the low-rent district of LA, so in the pre-student loan period we pretty much all worked, or like me; in the military by popular lottery.
Either way, I like the design of the regular Thule system, aside from being able to put it on both cars as necessary. Longer bars are a plus.
Old Mar 4, 2023 | 09:54 PM
  #63
yangpei's Avatar
Will the Yakima SmarT-Slot Kit 2 and FatCat EVO6 rack work on theThule Wing Bar EVO bars?
Old Mar 5, 2023 | 09:39 AM
  #64
Dogpilot's Avatar
Since I modified my rack's mounts, I just ordered some T bolts off Amazon and used them;
T Bolts T Bolts
This is the size that the flip over tensioner uses (the flip over black paddle that comes with the Fat Cat), I just felt better getting ones that if I had to saw off a bit I would not be groaning. I also just cut some blocks, thinner, from Starboard. This lowered the rack some more. Thule slots are all the same size, so far as I have seen. So any T bolt that is slightly smaller than the slot will slide in. These have been in place since November and countless trips up the mountain without issue.
Old Mar 6, 2023 | 07:23 AM
  #65
GCSchmidt's Avatar
Yes, the Yakima SmarT-Slot Kit 2 and FatCat EVO6 will work on the Thule Wing Bar EVO.
Old Apr 1, 2023 | 03:52 AM
  #66
Mrptee's Avatar
Default Height
Hi there,
Do you happen to know what the total height of the vehicle is including the roof rack and yakima ski/snowboard holder?
I live in an apartment building with 2.1m maximim height so I’m trying to find/see if there is a snowboard holder that will fit.
Thanks in advance,
Paul
Originally Posted by GCSchmidt
I am using the Factory Cross Bars with the Yakima FatCat EVO 6 Ski/Snowboard Mount (Silver) attached with the Yakima SmartT-Slot Kit 2 T-Slot Adapter.
They are super low profile, especially with the SmarT-Slot Kit. Virtually zero wind noise, the sliver matches the factory cross bars perfectly. I would recommend this set up to anyone. I do have the factory ladder, which I use to put the skis on/off.
LR Factory Cross Bars
Part #: VLPER0178
LAND ROVER ACCESSORY FITTING INSTRUCTIONS
https://yakima.com/products/fatcat-6...30947665707056
Instructions: FatCat EVO 6
https://assets.yakima.com/product/in...ions/8003097/1
https://yakima.com/products/smart-slot-kit-2
Instructions: SmarT-Slot Kit 2
https://assets.yakima.com/product/in...758.1664823657​​​​​​​
Old Sep 5, 2023 | 05:07 PM
  #67
yangpei's Avatar
I finally pulled the trigger on a new roof rack / ski carrier setup. I decided to go with the Thule Wingbar EVO 50" bars paired with the Kuat Grip 6 ski carrier with Kuat's direct mount. I compared the Kuat Grip 6 with the Yakima Fatcat 6. The Kuat felt a little sturdier / better built and also had the sliding feature, which may make loading / unloading easier.
https://www.thule.com/en-us/roof-rac...vo-_-am711xxxb
https://www.rackattack.com/rooftop-s...ki-rack-black/
My Defender 110 won't be delivered until Oct, so I'll post f/u pics later.
Old Dec 9, 2023 | 01:06 PM
  #68
yangpei's Avatar
Kuat Grip 6 installed. The M6 x 25mm bolts included with the Kuat direct mount adapters were a little short, so I went with M6x30mm bolts instead. Ready for skiing / boarding!
Kev M
Feb 27, 2026 12:58 PM
TripleThreat
Dec 26, 2023 11:44 PM
Defensor
Jul 27, 2023 05:15 PM
lr3-bb
Sep 3, 2022 07:54 PM
TripleThreat
Apr 10, 2012 04:49 PM
