Snow Tire Recommendations?
Old Oct 31, 2023 | 03:19 PM
chuyn's Avatar
Originally Posted by PaulLR
I run Nokian winter tires on all 4 of our vehicles and highly recommend. They have helped me make it the slopes in the worst winter conditions.
https://www.nokiantires.com/snow-win...liitta-r5-suv/
Years ago when Canada made winter tires mandatory, there was a winter tire shortage and I had to get Blizzaks. Great at first, but once half worn they turn into an all season tire. Nokians have far deeper sipes for ice traction, plus a wear indicator that tells you how much tread is gone.
For this same reason about the Bizzaks’ winter compound being only half the tread depth, I went with Michelin X-ice Snow. They feel as good or even better than the last Bizzaks I used and I’m happier about the compound being fully winter. I’m running mine on 20’s (275/55r20) but I’ve seen them in the 225/70r18 size as well
Old Oct 31, 2023 | 03:56 PM
Myron's Avatar
Thanks very much for posting that link @paule ! It does seem like it's hard to go wrong with either the Hakka or the X-Ice.
Old Dec 11, 2023 | 10:03 PM
NoWayMe's Avatar
Went with a set of Rotiforms and 275/55/20 Hakka studded tires.
Old Dec 11, 2023 | 10:39 PM
GavinC's Avatar
3rd season on this set of Blizzaks is off to a good start.
Old Dec 19, 2023 | 07:57 PM
msgm1's Avatar
Myron,
Your roof tent looks amazing!
Does it change the handling of your car? Does it have increased levels of wind noise?
Which brand is it?
Old Dec 21, 2023 | 05:17 PM
mdgs's Avatar
Originally Posted by WAFOX
I bought the extra set of steel wheels and Bridgestone Blizzak's from lucky8 for my winter setup.
Same for me! I am a true believer of the ‘Zaks!
Old Dec 22, 2023 | 11:03 PM
buzzinfrog's Avatar
I am confidently driving in winter conditions with my 22’’ Michelin Pilot Alpin 5 SUVs. They have a separate line for direct snow contact named x-ice but we don’t have ful season winter cover so not necessary for me.
Old Dec 22, 2023 | 11:24 PM
bridgestreet's Avatar
just put Michelin x-ice on this year. Will let you know how it goes, should have snow next week.
Old Jul 2, 2024 | 05:04 PM
Kaylorsan's Avatar
Paul, sounds like you have the r5 SUV in 275/55 20. Is that correct? Any issues at all with rubbing? I don’t see the r5s in 255/60.
Also, what wheels are you using with them?
Thanks.
Old Jul 3, 2024 | 06:20 AM
PaulLR's Avatar
Also, what wheels are you using with them? Thanks.
275/55/20 fit perfectly with no rubbing and the speedometer is still accurate since overall diameter is about the same as the 255/60 OEM tires. I bought a set of five 20" take-off wheels on eBay. Probably a good idea to get 5 winter tires since it could be difficult to locate a replacement tire in late winter if you blow out a sidewall on a pothole.
