SOS limited functionality warning
The following 4 users liked this post by Jbiggzs:
NativeTexan (11-16-2023)
The following 4 users liked this post by zac431:
Super Helpful!
Easy job if you are willing to pull some interior panels. The battery is located behind the driver side rear door. Attached are a couple pics I took when I replaced mine. The battery door had a single screw. I can't remember if it was a normal torx or security torx, but it was small.
i did not take as much of my panel off; but enough to get in there and swap out the battery!
Video Walkthrough to change battery
Decided to film the process - as much as I could - to also help others out there.
that Land Rover part was spot on.
SOS System Limited Functionality Warning Message for New Land Rover Defender MY24 - How to fix
To change yourself you will need the following part:
LR 132077 (battery - was $80 in Los Angeles)
Torx 10 (to open battery compartment)
Whatever else makes you feel comfortable when opening interior body panels
Note: the lower body panel has the following clips (top to bottom)
White Pop Clip
Yellow Clip (I broke this)
White Pop Clip
Metal Pop Clip
White Pop Clip
White Pop Clip
Metal Pop Clip
