SOS limited functionality warning
Old Nov 13, 2023 | 06:59 PM
NativeTexan's Avatar
Default TCU location for SOS limited functionality warning
Apparently this caused by a dead battery on the TCU.
Anyone know where that’s located in a 110?
Last edited by NativeTexan; Nov 13, 2023 at 07:15 PM. Reason: Title and body change
Old Nov 14, 2023 | 10:36 AM
bobbo28's Avatar
This is a simple fix but one you will need to see the dealer to remedy…. Your TCU needs a new battery. Covered under warranty.
Old Nov 14, 2023 | 07:17 PM
Jbiggzs's Avatar
Mine was replaced by the dealer before I took delivery on my CPO Defender earlier this year. Part# LR132077 Battery that was on my invoice. I believe it's located in the right rear in the cargo in the electrical compartment.
Old Nov 15, 2023 | 08:15 AM
zac431's Avatar
Easy job if you are willing to pull some interior panels. The battery is located behind the driver side rear door. Attached are a couple pics I took when I replaced mine. The battery door had a single screw. I can't remember if it was a normal torx or security torx, but it was small.
Old Nov 15, 2023 | 01:42 PM
forzahog's Avatar
Did you have to put it into service mode first before swapping it out?
Old Nov 15, 2023 | 05:57 PM
zac431's Avatar
Nope. I left the main battery connected while I pulled and re-installed the SOS battery. No warnings and the SOS notification went away immediately.
Old Jul 13, 2024 | 09:17 PM
ponder's Avatar
Default Super Helpful!
this was super helpful.
i did not take as much of my panel off; but enough to get in there and swap out the battery!
Old Jul 13, 2024 | 09:18 PM
ponder's Avatar
Default Video Walkthrough to change battery
Decided to film the process - as much as I could - to also help others out there.
that Land Rover part was spot on.
SOS System Limited Functionality Warning Message for New Land Rover Defender MY24 - How to fix
To change yourself you will need the following part:
LR 132077 (battery - was $80 in Los Angeles)
Torx 10 (to open battery compartment)
Whatever else makes you feel comfortable when opening interior body panels
Note: the lower body panel has the following clips (top to bottom)
White Pop Clip
Yellow Clip (I broke this)
White Pop Clip
Metal Pop Clip
Old Jul 14, 2024 | 07:48 AM
wcc18999's Avatar
Very good information. Thank you all for this valuable knowledge.
Old Aug 29, 2024 | 02:39 PM
303JonS's Avatar
Default Be careful!!
Attempted this repair, unfortunately the connector for the batter came off the circuit board instead of the battery unplugging from the connector…new circuit board at dealer and install $2k. Bummer.
