SOS limited functionality warning
Old 08-30-2024, 07:53 AM
GrouseK9's Avatar
Received 1,279 Likes on 764 Posts
Ouch!! Yet another reason I need to take it to the Dealer while it's still under warranty.
Old 08-30-2024, 11:14 AM
Zondar's Avatar
Originally Posted by 303JonS
Attempted this repair, unfortunately the connector for the batter came off the circuit board instead of the battery unplugging from the connector…new circuit board at dealer and install $2k. Bummer.
This should be an easy repair by someone who is technically-skilled. Even sight unseen, I'm confident I could fix it in minutes, for example, and I'd like a look at the module anyway. You wouldn't happen to live in So Cal, do you?
Old 08-30-2024, 11:24 AM
nashvegas's Avatar
Received 1,253 Likes on 672 Posts
Great video btw. I was thinking as I was watching that it would be far better to undo the 2 nuts on studs that hold that little electronic ECU box on, remove that from the car, then remove the battery.
Old 08-31-2024, 09:34 AM
denhams's Avatar
Same thing happened to me. Although well intentioned, the instructions above are not what Land Rover recommend. You can find the workshop instructions here which warn that the connector can be easily broken. Also, the Gap tool cannot do the 'Telematics Control Module Battery Replacement Reset' (I reported that to Gap who reproduced the issue).
If I were to do this again, I would fully remove the panel and then remove the TCU from car. I did this after I broke the connector to find out what had happened. Removing the panel is a pain, but it's better than having to replace the TCU if you break the connector. The connector is very fragile and seems a poor design for a serviceable item.
Brandon318
08-25-2023 11:18 AM
ToiletDuck
10-10-2021 11:02 PM
AGCinFLA
10-19-2020 07:12 AM
Joseph T. Pergola
LR4
06-11-2019 12:39 PM
Daedrix
02-10-2013 12:04 PM
Quick Reply: SOS limited functionality warning
