Spacers for 275/55 R20 BF Ko2`s
Old May 31, 2022 | 10:34 AM
  #21
Greghar's Avatar
8th Gear
I'm using Bonoss 25mm wheel spacers in the rear. Choose them because they did not require me to swap out the bolts. Been very happy so far and quality seems excellent.
Oh, and i'm running 285/45R22 ET35
Old Jun 1, 2022 | 12:54 AM
  #22
Sa.hib's Avatar
Thanks! Nothing at the front?
Old Jun 1, 2022 | 08:38 AM
  #23
Greghar's Avatar
8th Gear
No, nothing in the front. Here is a picture of the fitment.
Old Jun 2, 2022 | 11:18 AM
  #24
Iceman153's Avatar
25mm spacers front will cause rubbing in access, I had to go down to 20mm front. I have 275/55/20 Cooper at3's fitted. Not sure why people are saying you need to grind studs to go under 25mm, my stock rims had indentations on the back to allow for protruding studs, check your spare to confirm. I did 30 on the rear no problem however. In hindsight maybe 25mm on the rear may have been slightly better, purely from a visual standpoint.
also, there is nothing douchebaggy about this stance, the tires do not go past the body work. They just fill up the wheel arches a little more, and IMHO are how the defender should have come stock, it just looks right.
Yulongtd6
Dec 18, 2021 07:12 AM
LR03NJ
Aug 24, 2017 09:02 AM
me 2
May 15, 2013 06:49 AM
Soccer Dad
Jul 25, 2010 07:03 PM
