Speaker buzz D90
I've only read a couple threads re: that problem. Not common. You likely have something loose or, worse, a bad speaker. I'd recommend going into the PivoPro and changing the audio controls to go extreme front right, front left, rear left.... to try to isolate it to one area/speaker(s) or the entire unit/bass. If isolated, you may be lucky and something is lose. However, I think you have won the "take it to the Dealer" lottery and wish you good luck.
leddifer
Audio/Visual Electronics
05-15-2010 05:02 PM
