Steering wheel loose/clicking
Old Jul 10, 2024 | 05:01 PM
SilverSFR's Avatar
Are our defenders steer-by-wire?
Old Jul 10, 2024 | 05:05 PM
Mrlandrover's Avatar
i don't think so: there is a shaft towards the steering rack, but electrically assisted steering: no hydraulics from what I could gather.
Old Jul 11, 2024 | 12:26 AM
mmbanf's Avatar
https://static.nhtsa.gov/odi/tsbs/20...46414-0001.pdf
HI,
look at this recall, another cause of clicking at the front are the clips on the lower protection shield.
Marco
Old Jul 11, 2024 | 08:10 AM
Will do. Thank you for suggesting it.
Old Jul 11, 2024 | 09:10 AM
WTFChuck's Avatar
HI,
Marco
Good find. Thanks for sharing. Hope this helps the OP.
Old Aug 8, 2024 | 09:23 AM
I went to the dealership (for a second time) for this (steering knock) and a rear diff clunk and drove with the tech. He did not feel any knocking in the steering wheel but did his thing and rechecked tie rods, steering components. I mentioned the lower protection shield and apparently no issues there either. It has been much cooler here in the NE so the steering knock is much less pronounced.
Once I felt the knock today I turned off the car, parked and checked (locked steering wheel: only able to move a couple degrees either way) heard a mild knock deep in the front. Is this normal play with a locked steering wheel? I don't want to go to the dealer for a third time to be told it's normal. The loaner I drove (a Discovery) had none of the steering knocking going through the same roads.
update: checked and the E12 (torx) bolt at the steering pinch is appropriately fastened (30N, 22lb/ft). Back
to the drawing board.
DiscoNewbe
Oct 21, 2021 12:01 PM
antichrist
Feb 25, 2020 08:50 PM
steaktaco
Mar 20, 2019 03:09 AM
archaeology_student
Jun 8, 2013 11:04 AM
The Image
Jan 5, 2008 05:43 PM
