SwithPros SP9100 Intallation
#21
I used the following distribution block from Amazon:
12 Terminal Distribution Block -BUSBAR- with Ring Terminals
#23
#24
Pangea123 (01-16-2024)
#26
The white wire is the light input for dimming when you turn on your lights, I connected mine to the passenger marking light in the wheel well.
The following is from the instruction manual:
LIGHTS Input/T2, White wire. Turns on switch panel backlighting to user set level. Trigger 2 input if enabled. Connect this wire to a parking light signal or a side marker light signal. Use a T-tap to make the connection or solder and seal. This wire is used to dim the switch panel backlighting for night time lighting. The backlighting and switch indicator led brightness intensity is set by pressing the programming switch (located behind the SWITCH-PRO logo) on the switch panel 3 times. Switches 1 and 2 adjust the led switch indicator brightness and switches 7 and 8 adjust the backlighting intensity. Once the intensities are set, press the program switch again to exit. When used as a trigger signal, it can turn on up to 4 outputs with Active High or Active Low signal. On Side by Side UTV vehicles, like Razors and CanAm’s, that do not have parking lights, connect the White “Lights” wire to the Lt. Blue “Ignition” wire. Then connect both to an 12V ignition or accessory source.
https://www.switchpros.com/wp-conten...s-00285489.pdf
Pangea123 (01-18-2024)
