T-Bolt Size for OEM Roof Rack
Old Feb 17, 2025 | 10:44 AM
jmoney05txst's Avatar
Default T-Bolt Size for OEM Roof Rack
I have a couple of things I need to hard-mount to the roof rack, and I need to order some T-bolts for the grooves. Has anyone done this and know the size and/or a quality place to order some from?
Thanks.
Old Feb 17, 2025 | 03:28 PM
DonMitsu's Avatar
I know it's the same size as Thule crossbars. I've used these, and they fit perfectly: https://lucky8llc.com/products/stain...44685666943189
Old Feb 17, 2025 | 03:42 PM
Jim 90's Avatar
Got mine from powerful uk, but also pleased with lucky8. Not hard to get parts ( metric) from local store, but both powerful and lucky8 are very easy.
Old Feb 17, 2025 | 05:49 PM
GavinC's Avatar
T-track bolts from Amazon. Get the size you need. M6 or M8.
etraiker also sell Thule copies but the Amazon ones fit just as well and are cheaper.
I’ve used both.
Old Feb 18, 2025 | 05:23 AM
Thanks all, this is exactly what I needed.
Old Feb 18, 2025 | 11:30 PM
queezy's Avatar
After too much trial and error, these do the job perfectly:
T Slot Bolts for Thule
Amazon Amazon
M6 20 mm x 20 mm x 3.5 mm Square Carac Nut
https://www.etrailer.com/Accessories...ck/RR29TB.html
and in case you haven’t found these yet:
Replacement Cover Strip with Pattern for Thule AeroBlade Edge Cross Bars
https://www.etrailer.com/Accessories...le/TH69JH.html
Cliffplaysdrums
Aug 12, 2023 06:00 PM
nac
Apr 17, 2023 02:21 AM
Mcdooogs
Mar 25, 2023 07:15 PM
Mark1107
Apr 9, 2022 08:07 AM
