Tasman 110 w/ Rotiform STL's + BFG
Old 07-20-2022 | 01:46 PM
GavinC's Avatar
Aren't these 20" and steel?
Must weigh a fair chunk.
Old 07-20-2022 | 02:11 PM
CombatNinja's Avatar
Are these the exact same wheels the Vulkan Automotive sells?
Old 07-20-2022 | 09:21 PM
gtbeale's Avatar
Originally Posted by 2thebrim
Where did you get them from?
https://www.wheellab.us/rotiform-stl...-r19120902161/
Pretty sure they are forged aluminum, but let's be honest it's a big wheel so it has some weight. Then again so did the stockies.
Looks like the center cap area is a bit different
Old 07-20-2022 | 10:22 PM
NoGaBiker's Avatar
Forged? For real? Our GT4s didn’t even come on forged alloys (they’re cast.) Which is not to say the Rotiforms aren’t forged — I don’t know anything about them. But five of them are going to be $8-10,000 if they are, I bet. And 20” forged wheel should way around 20# or less in our widths.
Old 07-21-2022 | 06:45 AM
MattF's Avatar
Cast monoblock
​​​​​​https://www.rotiform.com/wheel/65233.../?styleID=4200
Old 07-21-2022 | 03:32 PM
There is a forged STL from Rotiform staring at $1500. Each. Assuming most sets you see are going to be the cast aluminum version. 37 pounds for 20' x 9' in case anyone is curious. So probably not far off from what the stockers weigh. They are not exactly light.
Old 12-22-2022 | 07:41 PM
Lbj9189's Avatar
Default STL fit
Greetings,
Question, the center bore of the Roitform STL is 72.5 mm, the L663 center bore I believe is 72.6 mm. Was there any issue with this difference? Thanks
Old 12-22-2022 | 08:19 PM
gtbeale's Avatar
Originally Posted by Lbj9189
Greetings,
Nope all good
Old 12-27-2022 | 05:41 PM
2thebrim's Avatar
Greetings,
I have the 18” version of this wheel and I have had a slight issue with the center bore of the wheel being slightly smaller than the L663 hub. I don’t think the 0.1mm would cause the issue and I’ve measured the center bore of the wheel, which is true to mfg spec. Saying that, I may need to increase the center bore ever so slightly after I get the brakes sorted to get everything fitted.
thaddh
04-25-2022 12:52 PM
4Corsa
08-15-2021 08:23 PM
BAA1
10-30-2019 10:13 AM
Ellingson Classic Cars
05-23-2016 11:55 AM
savedsols
11-05-2007 08:10 AM
Quick Reply: Tasman 110 w/ Rotiform STL's + BFG
