TDI Tune
Old Jan 24, 2022 | 12:36 PM
  #71
TrioLRowner's Avatar
Originally Posted by Muppetry
This paper primarily addresses a potential error in calculating relative O₂ concentration from absolute O₂ concentration in mol m⁻³, due to the variation of partial pressure with pressure, temperature and concentration. That shouldn't matter for a turbo, since all it cares about for combustion stoichiometry is absolute concentration.
ok, so does anyone know reportedly why turbos do not function at their most robust at low outside temperature?
Old Jan 24, 2022 | 12:39 PM
  #72
GrouseK9's Avatar
Not me, the longer I live beyond college mathematics the more my math skills regress. I'm hell on wheels with Excel spreadsheets these days, but beyond that I've got nothing. Interested in the topic, though.
Old Jan 24, 2022 | 12:48 PM
  #73
Muppetry's Avatar
I didn't know that was a common problem, and a quick Google search doesn't seem to bring up much on the subject. I did find one short discussion of the subject relating to GM vehicles:
https://gm-techlink.com/?p=11016
It mentions a few different issues, but the main one appears to be moisture condensing and freezing in the air cooler.
Old Jan 25, 2022 | 12:14 AM
  #74
Ehloo's Avatar
simple answer is cold air is more dense and holds more oxygen.
turbos love cold air but when too cold the ecu is over compensating
i love early morning drives in my tuned m8. it is also running a piggy back tube but was customed tune. so not off the shelf. throttle response is amazing. but i love in California and the coldest it gets is low 30’s and that’s once and awhile
Old Jan 25, 2022 | 08:32 AM
  #75
Muppetry's Avatar
That's not really an explanation. The ECU is overcompensating for what? And why is cold better than hot, but too cold worse than cold?
Old Jan 27, 2022 | 12:55 AM
  #76
Ehloo's Avatar
there is a reason why i said simple answer. quick google search can explain why cold air is better than hot for turbos
if you research in more detail many have issues with their cars in extreme temperatures.
the ecu is over compensating then increasing fuel and in some cases running rich or not providing enough fuel and running lean, or enough fuel for the oxygen intake
quick summary of the link. cold air is more dense. you will notice you car perform better in normal cold temps compared to a hot summer day
https://www.turbodynamics.co.uk/medi...sonal-weather/
Old Jan 27, 2022 | 08:55 AM
  #77
Muppetry's Avatar
That link addresses why turbos perform worse in hot temperatures. That wasn't the question, which was about why they might perform worse in very cold temperatures, so your "quick Google search" didn't work.
Old Jan 27, 2022 | 06:18 PM
  #78
Ehloo's Avatar
sorry cant help you if you can’t figure out from the link.
it’s pretty detailed and answers your questions.
maybe you should try reading it
Old Jan 27, 2022 | 06:28 PM
  #79
Muppetry's Avatar
No - I read it, and it is just about why turbos perform better at lower temperatures. As for detailed, it's about as superficial as it gets. If you don't actually know anything about this subject then you might consider simply not posting.
Old Jan 30, 2022 | 12:29 AM
  #80
nashvegas's Avatar
I have had turbo cars for 30 years and ... guess what, as we all know, they're faster when it's cold.
Turbochargers do not perform worse at low temperatures. If the claim is that modern engine management software backs off the power at extremely low temperatures, which means that "the car performs worse"... then, that's what is happening. If you are wondering the *reason* why... well, then, I don't know. And who cares. It's emissions related (most likely). And are we actually racing a Defender at subzero temperatures?
In other words, this thread is becoming rather tedious...
