Time for instilling accessoires
Old Feb 19, 2023 | 02:03 PM
Balleur's Avatar
Default Time for instilling accessoires
Time for installing accessoires?
my dealer is offering me some bought back stuff.
a large Frontrunner rack with lazerlamps 42
2 workinglights ont the back
the side box oem
the ladder oem.
he quoted this time for installing
rack 3 hours
lights cabeling in the car 2 hours
the box and ladder 1 hour
installing auxbeam switchbox 4
seems a long time?
Old Feb 19, 2023 | 03:05 PM
MattF's Avatar
I just installed the following:
FrontRunner rack OEM rails version. This version does not require removing the roof rails. I am assuming this is the same as the roof rails are required for the ladder and lunch box. - working alone it took me an hour to assemble the rack and a couple of hours to install. Note - this was working alone.
Ladder and lunch box - 2 hours total. I could do it in half that time now that I know what I'm doing.
Old Feb 20, 2023 | 10:06 AM
DefenderSISU's Avatar
Dealer wants $5500 to install the bull bar in mine and I had to pass that is more than the bar costs including shipping. I don’t believe it’s too long just have to find out the hourly rate that they charge to see if it’s too expensive.
Old Feb 20, 2023 | 01:18 PM
TeddyG's Avatar
Is it hard to remove if needed? I'm considering using smaller front runner on OEM rails for one off trips maybe once or twice a year.
Old Feb 20, 2023 | 03:39 PM
MattF's Avatar
once it’s set up and installed it shouldn’t be that difficult to remove. It’s by no means meant to be taken on and off.
There are six mounting feet. The mounting feet are basically comprised of two parts. The part that attaches to the roof rails and the part that is attached to the rack. These are bolted together so I suppose you could unbolt them and leave the roof rails mounts in place.
You’d need two people or a hoist. The rack weight is approximately 70lbs.
Old Feb 23, 2023 | 08:18 PM
Nati's Avatar
I've also got my eye on the front runner rack version for the OEM rails. My issue with any roof storage option is the clearance day to day. I'll need to have it off unless I'm camping.
if the mounting feet are left in place, are they taller than the fin antenna?
Old Feb 23, 2023 | 08:36 PM
MattF's Avatar
I’ll check for you tomorrow
Old Feb 24, 2023 | 09:34 AM
Default Fin height versus roof rack support height
Fin height is 7cm and support height is 10cm
Old Feb 24, 2023 | 10:59 AM
Nati's Avatar
Thanks very much. Would that height measurement for the support be with the “fixed” portion of the foot only (I understand the foot is two pieces bolted together - it struck me that one could perhaps unbolt the supports and leave the “top” half connected to the rack when it’s removed - maybe that would save a centimeter or two, but maybe not).
Old Feb 24, 2023 | 03:32 PM
Balleur's Avatar
Thanks guys, dealer lowered the time for installing wit 35%
ficklma1
Feb 12, 2023 01:18 PM
wcc18999
Jan 9, 2023 01:01 PM
Lantisbred
Defender
Jun 6, 2022 11:01 AM
N E WHR
Jan 17, 2022 02:50 PM
nickSF
May 9, 2021 03:51 PM
