Top rear fin?
Old 03-07-2022, 07:53 PM
Xploit's Avatar
Default Top rear fin?
Is that fin thats on the top rear for the clearsight?
Old 03-07-2022, 08:29 PM
nashvegas's Avatar
Received 1,252 Likes on 672 Posts
It has the satnav/antennas for things internally -- but yes, it's also the mounting location for the clear sight camera.
Old 03-07-2022, 09:15 PM
Xploit's Avatar
So all defenders have the fin then? I have seen pictures of defenders in Europe without it, I think it looks better without.
Old 03-08-2022, 12:37 PM
Brock Samson's Avatar
I have never seen one without the fin. Clearsight fin is slightly larger, but it is on all defenders.
Old 03-08-2022, 12:39 PM
Xploit's Avatar
Heres one where I cant see it
Old 03-08-2022, 12:43 PM
Oh, that is good to know.
I have a slight height issue in one garage I need to access, maybe it can be replaced with something flat.
Old 03-08-2022, 03:49 PM
_Allegedly's Avatar
Received 1,412 Likes on 713 Posts
How much more clearance do you need and what kind of opener do you have? Almost all openers can be very easily adjusted to travel a little higher.
Old 03-08-2022, 03:56 PM
GavinC's Avatar
Received 2,505 Likes on 1,016 Posts
I can see it.
Old 03-08-2022, 08:38 PM
GrouseK9's Avatar
Received 1,279 Likes on 764 Posts
Any Defender (90 or 110) trim level you have built in the NAS will have that fin. If you go to the configurator, it appears that all trims levels and body styles have it because it contains all of the nav, etc. antennas.
That could have been a ROW (Rest of the World) spec or one of the many myriad options that are no longer offered.
Old 03-08-2022, 10:06 PM
Thanks , but it is not a door issue, it is a low drainage pipe.
I can get under it, but only on one side, it is about 1.5 cm too low at the worst point.
Quick Reply: Top rear fin?
