TPMS Indicator Blinking?
Old Jan 13, 2026 | 03:46 PM
RickBullotta's Avatar
6th Gear
Default TPMS Indicator Blinking?
Hi, all. 2025 Defender V8 110, about 5000 miles on it. Today, the TPMS indicator light starting blinking, then goes solid. Per the manual this is a communication issue, apparently with all four tires. Obviously it's not the TPMS sensor or the batteries in the sensors. Any clues/suggestions?
Thanks,
Rick
Old Jan 13, 2026 | 04:28 PM
chpsk8's Avatar
What do your tire pressures read on the dash? Compare them to the actual pressures and see if there is a misalignment.
Has it been cold outside?
Old Jan 14, 2026 | 05:43 PM
6th Gear
FYI, the TPMS receiver had lost communication with all of the sensors. Shutting the truck down and letting it fully shut off overnight, then giving it a minute or two to reestablish communication after starting it the next day did the trick.
Ehloo
May 23, 2022 03:38 PM
Lnberger
Apr 16, 2022 04:05 PM
