TPMS warning not resetting
Old Apr 7, 2024 | 10:18 PM
Foxpeak's Avatar
4wd High
Default TPMS warning not resetting
About a week ago, I got a TPMS warning that the left rear was a little low. I checked it and found no puncture, so I added air. Since then, the TPMS warning hasn't gone away - even though the left rear now has more air than the other tires. (See pic below.) I tried clearing the warning, resetting Pivi, driving over an hour and locking and waiting - but it still won't clear. I couldn't find any way to manually reset the TPMS. Any suggestions? Thanks.
Old Apr 7, 2024 | 11:32 PM
GavinC's Avatar
change it to light load setting and it will go away.
Then switch back to whatever setting you like. Assuming you're over regular load setting it will not come back if set to same
Old Apr 8, 2024 | 12:00 AM
Dogpilot's Avatar
Normally, to make them reset is to fill the tire to 5-8 psi over, then let air out to recommended pressure. Another way: hold the lock and unlock buttons down on the key fob, the car will chirp. Then hold one of those really strong magnets near the base of the valve stem. Kind of move it around and adjust which pole is pointing where. You will know it has reset, when the mirrors magically waggle, kind of cool, like an angry hippo.
Old Apr 8, 2024 | 09:57 AM
Foxpeak's Avatar
4wd High
Thanks, guys. Switching to Light Load setting for a brief drive worked great. All clear…
orangeman
Jun 26, 2023 12:33 PM
rknighton
LR2
20
Aug 14, 2022 10:34 AM
drcoop
Apr 26, 2022 08:32 AM
2019D5
Sep 22, 2021 10:41 AM
lr3def
Jan 12, 2008 05:30 PM
