Used GAP IID Tool to enable Approach/Walkaway Locking in CCF
Old Aug 27, 2023 | 06:56 PM
ficklma1's Avatar
Default Used GAP IID Tool to enable Approach/Walkaway Locking in CCF
I successfully updated/enabled Approach/Walkaway Locking in CCF file on MY2023.5. However, going into the PIVI screen to enable/selecting via the screen they will not stay enabled. If I leave the screen and go back both the approach and walkaway settings are disabled. Any ideas what could be causing this?
Old Aug 28, 2023 | 07:29 AM
gurka01's Avatar
Earlier models for some reason allow the config to be set but they are not supported. Mine is a 2020 and I have the same result. The auto start stop disable is the same. No one has been able to explain why as far as I know
Old Aug 28, 2023 | 07:59 AM
ficklma1's Avatar
Yes, I've read that as well, but mine is a MY2023.5 with no locking fuel door, etc. So it really doesn't make sense why it isn't working.
Old Aug 28, 2023 | 08:27 AM
MickD's Avatar
It works on my 23.5.
  • Have you power cycled the Pivi?
  • Were you able to configure auto start/stop?
  • Is your KVM module unlocked on this screen? This is unrelated but I'm curious as mine is unlocked when it should not have been
Old Aug 29, 2023 | 03:46 PM
pjeski's Avatar
I have this issue, but i haven’t intentionally reset the pivi yet. I’ll try that soon. Remember auto start/stop and belt minder are working, though.
Old Aug 29, 2023 | 06:32 PM
pjeski's Avatar
I just got home, and reset my pivi. After the reset, I set approach unlock in the menu, and checked that it persisted. Went in the house, back to the garage, it unlocked as I approached. Also now wifi hotspot is on the menu. I'll play with that later.
Old Aug 30, 2023 | 09:45 AM
Dan Hairy's Avatar
If you ever have a problem with something not showing up in Pivi you can execute the command
Menu>Service Test>IDMA>Allow Central Configuration Data Learning and that will force Pivi to look for changes
Old Sep 2, 2023 | 11:48 AM
pjeski's Avatar
I don't have an IDMA item in my service/test menu. Is that just for the people with the nice all digital clusters?
Old Sep 4, 2023 | 08:20 AM
ficklma1's Avatar
This was the issue indeed —> I needed to reboot or force the Pivi to accept the changes! I personally thought that since it had sat for several days that it didn’t need to be rebooted but that was the issue.
Thank you all for your help!!!
Philip Chan
Jun 21, 2019 11:23 PM
2006LR3
Sep 19, 2017 06:30 AM
Niver39
Dec 9, 2016 11:17 AM
Colb.45
Jun 2, 2015 11:51 AM
