Water ingress - top door seal?
Old Nov 21, 2022 | 02:10 AM
XplusYplusZ's Avatar
Default Water ingress - top door seal?
We've had a pretty wet Autumn with plenty of rain, and I keep noticing water drops on the wrong side of the door seals. Mainly in the rear doors. I don't see any wet or damage inside the vehicle..yet.
I can't tell if the water ingress happens whilst the door is closed (ie. the seal is leaking), or only when I open the door and water is allowed to pass over the seal. I would have thought the top 'gutter' should act as a primary seal and prevent water running to the second/main o-ring type seal. But I'm starting to suspect the gutter is a little bit more rigid and might not be forming a perfect seal - leaving the o-ring to do all the work. It's annoying and I worry over time this will become a bigger problem. Does anyone else have this issue/fixed it?
It's more of an annoyance for the moment, I don't know if I should take it in or just accept this as a part of defender ownership..?
Water on the wrong side of seal:
Top 'gutter' - often empties water down my sleeve..
Old Nov 21, 2022 | 02:47 PM
nashvegas's Avatar
I have noticed this on both rear doors of my 110. I have determined, through very unscientific means (ie just opening the front doors and looking back) that these drops only appear inside the car after I've opened the rear doors. But -- I agree -- suspect and am watching it.
Also, my drivers door dumps water on me and / or the seat when it rains when I open it.
Kind of wish this thing had rain gutters like an old D1/D2/RRC.
Old Dec 28, 2023 | 12:28 PM
WAFOX's Avatar
Similar issue here with my front drivers door.
LeakyDisco
Dec 23, 2021 12:23 PM
zuke
Mar 7, 2018 04:54 PM
discoboy
Dec 20, 2012 02:24 AM
pilsner
Feb 8, 2009 03:50 PM
FranzUgan
Defender
May 25, 2007 03:20 PM
