Well, it won’t start - p300 4 cyl
Old Nov 2, 2025 | 08:40 AM
Bigarch's Avatar
5th Gear
Default Well, it won’t start - p300 4 cyl
When I hit the start stop button, only the infotainment system comes on. Nothing populates on the dash, nothing.
I tried to jump it with my wife’s car. Then with a battery pack jumpstart thing from AAA. Nothing.
key fob works and locks and unlocks the car.
is it the battery? If so the one under the passenger seat or the one under the rear luggage compartment.
or a different issue entirely? Any help is appreciated!
Car details. 2021 Defender 110 P300 4-cyl 45000 miles.
Old Nov 2, 2025 | 10:17 AM
RH5555's Avatar
I'd try disconnecting the battery, wait ten minutes, then reconnect. Force a complete reboot...
Old Nov 3, 2025 | 07:22 AM
sarek's Avatar
Put the key under the column and try to start it
Old Nov 3, 2025 | 08:04 AM
Bigarch's Avatar
5th Gear
Default Ok that worked.
So I pulled the negative cable off the battery for 10 mins and put it back and it started right up. The ECU needed a hard reset. I’d recommend keeping a spanner 10mm, in your tool kit int the back.
I also attempted, miserably, to change the battery myself. I got the seat disconnected and off but couldn’t get the actual battery out. So it’s in the shop today. $800.
Old Nov 3, 2025 | 08:54 AM
SilverSFR's Avatar
I am curious as to what part of the battery removal you had trouble with? You mentioned that you have the seat disconnected and off/out of the vehicle? Was it the weight or angle of the battery?
Old Nov 3, 2025 | 09:23 AM
Bigarch's Avatar
5th Gear
it just wouldn’t move. It was connected somehow to a housing that I couldn’t see.
the other issue was the reset of the computer. I don’t have a gap tool; which I’m thinking I need but they are pretty pricey.
Old Nov 3, 2025 | 11:03 AM
RH5555's Avatar
Just had my battery replaced by dealer. Only $528 including tax. I was pleasantly surprised.
Old Nov 3, 2025 | 12:01 PM
Bigarch's Avatar
5th Gear
I was $825 out the door but there was a loose wire that needed to be repinned that they charged me another .5 hrs of labor.
not great. Not the end of the world.
Old Nov 3, 2025 | 01:02 PM
Juancl's Avatar
P300 D90 with 47,500 miles. Back in May I left my car at the dealer for a "final month of warranty" thorough inspection (had them check every little thing for potential issues). Can't be happier with my SA, last service before warranty expiration included new battery, new coolant system hoses and expansion tank and new front wheel bearings.
When did your warranty expire? It’s not unheard of that with a bit of pushing to JLR they might cover repairs that come up right after warranty expires (it's not guaranteed, but it doesn't hurt to ask if the failure came close after warranty expiration).
Old Nov 4, 2025 | 10:28 AM
DoctorofRocks's Avatar
I tried to do that as well - but they weren't interested. Had previously been happy with Jake Kaplan Land Rover in Warwick, RI but skipping that request and forgetting to reset the "change oil soon" warning after charging me over $1000 for a 42k service has left me questioning what else they "forgot" to do.
Did you pay them for their time to do this inspection?
