What is the Single, Simple Change You'd Like to See on Defender?
Old Mar 15, 2024 | 05:39 PM
  #141
SoCal Al's Avatar
Originally Posted by gb_junkie
Good thread! Love my defender - but sure do wish it had the following:
-passenger door lock/unlock button
-aluminum skid plates for the fuel tank
-rear floor mounted cup holders/slide out cup holders
-base model gets rear seat back pockets and center armrest (baffling that a 50k car doesn’t have this)
-more wheel travel for coil sprung models, also an extra 1.5” of height (Land Rover should assume folks that get coils aren’t being cheap, we actually want to go off road). Along those lines, a Sasquatch/Rubicon like package with real tires and aluminum sliders - because people are actually cross shopping the Wrangler and Bronco with the Defender.
-exposed front recovery hook
-thicker windshield
-OEM bull bar option for the US
-charge way less for painting the roof a different color
Agree these are nice & doable but I'd also add an aluminum lower valence skid plate to replace that plastic panel (which would be a bear to remove in the field to access to tow hook!)
Old Mar 15, 2024 | 06:47 PM
  #142
TeddyG's Avatar
absolutely, and plus resolve battery drain issue.
Old Mar 15, 2024 | 09:01 PM
  #143
markjlr's Avatar
LR Forum Vendor
you can retrofit an interior door button tailgate release. I did with a simple l494 tailgate button and a harness powerful uk sells to do it. Go to powerful uks YouTube channel you can do it easily. I think they sell kits now.
it releases the tailgate from the inside regardless if the truck is running locked unlocked armed etc, the button pops the door open.
Originally Posted by Drednot
I will add my 2 cents: A way to open the tail door from the inside, i.e. a handle, I know one could use the Smart Key, but I am thinking of a situation such as sleeping and the need to get out through the back feet first and without having to fumble around for the key fob.
Old Apr 2, 2024 | 05:20 PM
  #144
Trailmix's Avatar
A heat element on the rear camera used for Clearview mirror. A simple little circle of wire around the lens, to melt snow. This is my view every time it snows
Old Apr 2, 2024 | 07:45 PM
  #145
Jim 90's Avatar
Agree with SoCal Al -front tow hook exposure even if under shield is not included. Also add forced pivi pro updates and dealer CCF activations at a reasonable cost option.
Ehloo
Aug 16, 2022 04:51 PM
aao4473
Oct 27, 2021 09:42 PM
aleksei02
Oct 10, 2021 01:35 PM
aarongregor
Mar 18, 2013 01:58 AM
joedef90
Defender
Jul 5, 2007 05:06 AM
