Wheel size for AT tires on a P400?
Old Feb 17, 2021 | 12:06 PM
gts944's Avatar
Default Wheel size for AT tires on a P400?
I'm going to order a 2022 soon. For sharp rocks and sand in the American Southwest, I would assume that the smallest wheel size (19" for a P400) would be ideal. However, it looks like tire options are quite limited for the 19" size and that the wheel width is 8" (vs 8.5" for the 20"), which would limit non-standard tire width options.
Any thoughts on 19 vs 20?
Old Feb 17, 2021 | 02:12 PM
merrion13's Avatar
On this very page are 4 tire threads, encourage you to start there before creating a new post. Short answer: 19s much more limited in choices.
Old Feb 17, 2021 | 03:02 PM
DonMitsu's Avatar
If you're good with only Good Year 19's may work but very limited tires are available. 20 is best from the factory or Lucky8 may have the best solution https://lucky8llc.com/collections/de...brake-calipers
Old Feb 17, 2021 | 03:13 PM
gts944's Avatar
Thanks! I didn't realize the 18" kit was out yet. Guess I'll order it with 20's so I could later fit snow tires and have more AT selection in 18". That would be perfect.
Raptor84
LR4
Feb 1, 2018 07:10 PM
Snafu / Disco Fries
Mar 13, 2015 02:56 PM
apcollin
Tires
29
May 24, 2009 02:03 PM
trinidev
Aug 8, 2007 10:57 AM
