LR 4 255-55 R20 tires
Old Jan 10, 2018 | 06:09 AM
Raptor84's Avatar
Default LR 4 255-55 R20 tires
Looking at Bridgestone Dueler H/L Alenza tires. Tire rack prices 4 255-50s delivered for $902.68. 4 255-55 are $803.68. I don't know why the smaller tire is 25 bucks more but will they fit with no problems. Service writer at dealer says ok, tire rack rep. says they will rub. Anyone have some knowledge on this.
Old Jan 16, 2018 | 06:09 PM
BritCars's Avatar
I'm confused. 255-55 R19 is the correct size. Those are the ones you should get
The 255-50R19 is a smaller tire. So it can't possibly rub. But it's a half inch less sidewall so total wheel and tire diameter is an inch smaller. So your speedo and mileage will misread. By about 3% I believe
Old Jan 17, 2018 | 07:42 AM
Raptor84's Avatar
My LR 4 came stock with 255-50 R20 tires. I have decided to go with the Michelin Defenders in that size.
Old Jan 17, 2018 | 04:29 PM
BritCars's Avatar
Yes. Your wheel is an inch bigger in diameter so it uses a tire that is an inch shorter in sidewall. Giving overall the same total diameter
Most LR4s came with 19inch so I assumed that was the OPs setup. If he has the 20inch then the 50-sidewall is the right one and the 55 will be too big. Maybe that's what he meant - it would explain the rubbing comment.
For the OP - can you provide your wheel size?
Old Jan 17, 2018 | 04:33 PM
Raptor84's Avatar
My LR is a 2016 Landmark. I guess thats why I have 20" wheels.
Old Jan 22, 2018 | 09:12 PM
BritCars's Avatar
Yes. That will be why
So if you have the 20inch wheels I follow the point on rubbing now. I would suggest keeping with the 50 as they will have the same total diameter as intended and therefore avoid instrument misreading
I'd be pretty sure the 55s will fit in the wheel arches - there is a lot of clearance. But the speedo / odometer would misread a bit.
Old Jan 27, 2018 | 07:55 PM
Johnson Rods's Avatar
LR Forum Vendor
Default LR4 Tire Sizes
You can easily fit the 255-55-20 which is 31 inches with no lift.
Here is a tire size chart:
LR3, LR4, Tire Size Chart
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Feb 1, 2018 | 06:28 PM
BritCars's Avatar
But won't the speedo and odometer misread?
Old Feb 1, 2018 | 07:10 PM
Raptor84's Avatar
I went with the Michelin A/T in 255-50-20 and am happy with the ride so far. Very little road noise and good in the dusting of snow we have had.
Discovery66kz
Feb 7, 2011 04:46 AM
tuck
Nov 11, 2010 11:42 AM
gmutis
Tires
Jan 7, 2009 01:30 AM
jwalters
Oct 24, 2007 06:35 PM
jwalters
Oct 23, 2007 07:03 PM
