Windscreen wiper replacement for the cheapskate / environmentally sensitive person
Old Dec 7, 2023 | 11:32 AM
WMN's Avatar
WMN
Default winter blades...
Just saw this:
https://www.roverparts.com/winter-wi...d2h#sku-scroll
Thoughts?
Old Dec 7, 2023 | 11:44 AM
RH5555's Avatar
I think this is the right part for the Defender. Certainly a better deal than the ones from the dealer, so partially meets my cheapskate requirement, but fails on the environmentally sensitive. I am both... I really hate tossing out the whole arm for want of a dollar's worth of rubber.
Old Dec 7, 2023 | 12:31 PM
GavinC's Avatar
Yes. It's nice to repair rather than replace. Also $8 for the refill. Hard to beat that.
I think the little plastic tabs will stop any unwanted movement of the rubber. Not a big deal either way.*
*Probably oodles of man hours in the windshield wiper department went into the addition of those little nubs. Possibly someone's patent or life's work. I shouldn't be too dismissive.
Old Dec 7, 2023 | 08:19 PM
nashvegas's Avatar
I like this thread lots. There are reasons why manufacturers try to eliminate failure points for safety items, I believe that's their business rationale here for lack of available wiper refills / not offering it thru parts channels.
I've changed the refills only on lots of cars in the past (mostly 80's cars w' Bosch blades) and on one... (I believe a 1991 9000 Turbo), the rubber refill insert came out of the blade during a drive.... and then I was 1) without wiping on the drivers side going I'm sure far above the speed limit and 2) this scratched the absolute heck out of the windshield with the wiper arm without rubber because I kept them running while trying to look out the passenger side.
That cost me ... lots of safety as pulling over on a busy highway in Georgia in a monsoon is *unsafe* and also a new windshield as the scratches could not be polished out. Either the new rubber I installed wasn't right or wasn't properly in the groove, etc. Most of us can't be trusted to '"not f it up".
So -- Easier for them just to sell the entire assembly than repeat of scenario I described above.
That said I'd probably still try it on the Deefer to see if it works.
Old Dec 8, 2023 | 05:47 PM
Defenderphil's Avatar
Why would you go thru all that when there are many auto part store where you can get replacements for $18-40 with many choices.
https://www.autozone.com/ignition-tu...ade-windshield
Old Dec 9, 2023 | 08:16 PM
GavinC's Avatar
Well this is a great solution.
$8 and 5 minutes.
Old Dec 10, 2023 | 07:14 AM
WTFChuck's Avatar
Anyone know if this replacement rubber insert will work for the rear wiper as well?
Old Dec 11, 2023 | 06:38 AM
MattF's Avatar
This is VERY important !! The only source Ive found for the rear wiper is OEM due to the washer fluid dispensing design. Maybe one of you guys can try this?
Old Dec 11, 2023 | 07:53 AM
Ratledge's Avatar
Right. People (Otto comes to mind) will tell you they are compatible, but they don't have the water feed channel.
This works great! I had a chattering passenger side blade and replacing the harder rubber with silicone rubber makes it sit better on the windshield.
Old Dec 20, 2024 | 04:54 PM
GavinC's Avatar
Just did another front wiper replacement @GrouseK9
$6 for 4 blades so a $3 DIY for new wipers. Two left over for next time.
The rear wiper is not amenable to replacement with these as the rubber has a tubular cross section. It serves as it’s own washer jets.
You can see where the washing fluids go in the ovoid channel.
A few minutes of trimming like before.
Service position for wipers.
A close up of one of the pores on the rear wiper. There are many. Clever design.
A close up of one of the pores on the rear wiper. There are many. Clever design which AFAIK has since been superseded by LR
POPTOPP
Jan 12, 2024 07:55 PM
Low Country
Sep 19, 2023 09:05 AM
CombatNinja
Jul 17, 2022 01:10 PM
Fallstaff
Sep 2, 2020 11:11 PM
nick731
Mar 25, 2009 05:25 PM
