Wireless charging issues with iPhone 12
Old Apr 7, 2021 | 07:55 PM
crewcabrob's Avatar
Originally Posted by Hoosbest
One of my more annoying remaining issues. The BMW X7 seemed to fix the issue with a recent software update for my iphone 12. Works on that. My Defender - once in a blue moon.
My wifes 2021 X5 45e works every time with a 12 mini and 12pro. I didn't know there was an issue with the BMWs too.
rob
Old Apr 7, 2021 | 07:57 PM
Hoosbest's Avatar
I have a 2019 X7 - was an issue awhile ago but no longer.
Old Oct 19, 2021 | 09:54 AM
micmcm's Avatar
Same here, no iOS version makes any diff. To me it acts like it’s a sensitivity thing w the pad itself ie the thickness of the rubber mat
Old Oct 19, 2021 | 01:06 PM
rutiger's Avatar
tech bulletin SSM75427 resolves the issue. had this performed a few months back and phone charges reliably on the pad now.
Old Oct 19, 2021 | 01:45 PM
ajones0000's Avatar
8th Gear
FYI - It doesn't work with my new iPhone 13 Pro either. Worked fine with my old XS Max ...
Old Oct 19, 2021 | 07:12 PM
Hoosbest's Avatar
You can read other posts. Most of the Defenders came with a wireless charging pad that does not work iphone 12 and 13 - though works fine with older models. This is because of MagSafe on the newer phones. The dealer can 1) update the module for some later versions of the wireless charger. Older versions need to get an updated wireless charging pad. Mine did - and the new one works perfect with both the iphone 12 and 13.
Old Oct 20, 2021 | 07:49 PM
NoGaBiker's Avatar
Weird. My May 25 2021 build-date 110 charges my iPhone 12 (the little one, not sure what it’s called) just fine, 100% of the time.
Old Oct 21, 2021 | 02:07 PM
Vin's Avatar
Vin
Exactly, they updated the hardware. Problem solved.
Old Oct 21, 2021 | 06:40 PM
rutiger's Avatar
it's a software fix that has to do with foreign object detection (metal)
Action:
This procedure requires a minimum of Pathfinder (325) loaded or later.
Connect the JLR approved battery support unit.
Connect the JLR approved diagnostic equipment to the vehicle and begin a new session. Follow the JLR approved diagnostic equipment prompts.
Select 'ECU Diagnostics'.
Select ‘WDCM'
Select 'Update ECU'.
Follow all on-screen instructions to complete the task.
When all of the tasks are complete, exit the session.
Disconnect the JLR approved diagnostic equipment and the JLR approved battery support unit. Confirm the Wireless Device Charger Module (WDCM) charges the iPhone 12
Old Jan 7, 2022 | 11:25 AM
dsallean's Avatar
Action:
Select ‘WDCM'
Thanks for this. I did bring this info to the dealership and asked them to perform this software fix. They told me they tried and it wasn't available for my VIN. Who knows if that is true or not, but I still get no response when attempting to charge my Iphone 12 on the wireless charger.
