wireless remote switch for lightbar needed.
So My dealer can offer me a secondhand frontrunner rack with lazerlamp linear 42 up front and 2 working lamps on the back for my new to arrive defender 110 x.
Altogother probably cheaper then only the oem expedition rack, so sounds like a good deal!
i don't want it connected to my high beam. I want a switch, but remote switch, like a wireless switch board. so i can place it easily where i want. And i can operate it easily instead of reaching somewhere down. and maybe in the future add extra lamps?
Any advice on this?
picture is not my Rig, it will be build end this month.
Any advice on this?
Any advice on this?
Any advice on this?
I went with the AuxBeam panel as it’s only 1 small cable that came through the steering column collar. I fitted the panel and the control unit with SalTek Motorsports SP fitting kit, as I’d got front ditch lights, rear work lights and strobes and LED light bar also. Link to brackets below pictures.
https://saltekmotorsports.com/produc...ng-brackets-2/
Can I connect my lazer linear 42 to
this auxbeam and use the different modes with the lazerlamp? Front and back?
https://auxbeam.com/products/ar-800-...tem-qp008526-1
I’m led to believe if you add a common live to another switch option, then you can program that particular switch to flash, strobe or press and release.
The ditch lights and rear work lights, are the same brand, the outer led’s are the strobes, they can work independently or you can wire into the indicators with a jump loom that some suppliers have created.
bcolins
02-01-2015 07:05 AM
