wireless remote switch for lightbar needed.
Old Feb 11, 2023 | 03:31 AM
Balleur's Avatar
Default wireless remote switch for lightbar needed.
So My dealer can offer me a secondhand frontrunner rack with lazerlamp linear 42 up front and 2 working lamps on the back for my new to arrive defender 110 x.
Altogother probably cheaper then only the oem expedition rack, so sounds like a good deal!
i don't want it connected to my high beam. I want a switch, but remote switch, like a wireless switch board. so i can place it easily where i want. And i can operate it easily instead of reaching somewhere down. and maybe in the future add extra lamps?
Any advice on this?
picture is not my Rig, it will be build end this month.
Old Feb 11, 2023 | 07:49 AM
Ludders54's Avatar
Any advice on this?
I went with the AuxBeam panel as it’s only 1 small cable that came through the steering column collar. I fitted the panel and the control unit with SalTek Motorsports SP fitting kit, as I’d got front ditch lights, rear work lights and strobes and LED light bar also. Link to brackets below pictures.
https://saltekmotorsports.com/produc...ng-brackets-2/
Old Feb 11, 2023 | 09:32 AM
Balleur's Avatar
Thanks! That looks
good.
a few questions. Can you “flash to pass” the lightbar?
what lights and how do you use as strobe?
and great working lights. Amber in the side? Connected to indicator?
Old Feb 11, 2023 | 09:38 AM
Balleur's Avatar
Can I connect my lazer linear 42 to
this auxbeam and use the different modes with the lazerlamp? Front and back?
https://auxbeam.com/products/ar-800-...tem-qp008526-1
Old Feb 11, 2023 | 12:28 PM
Ludders54's Avatar
I’m led to believe if you add a common live to another switch option, then you can program that particular switch to flash, strobe or press and release.
The ditch lights and rear work lights, are the same brand, the outer led’s are the strobes, they can work independently or you can wire into the indicators with a jump loom that some suppliers have created.
Ludders54's Avatar
Yes, as per their description……..3 mode setting - Toggle/ Momentary/ Pulsed
mx468
Jan 14, 2023 09:15 PM
bcolins
Feb 1, 2015 07:05 AM
Northtosouthkaz
Jun 24, 2013 04:49 PM
discoguy96
Aug 16, 2012 03:56 PM
Chrisinhouston
Jan 20, 2009 11:47 AM
