Wiring Lightbar to High Beam - Diagram?
Old Mar 7, 2022 | 03:22 PM
Defendit..'s Avatar
@GrouseK9 @gurka01
I have also hooked up the auxilairy High Beams to the violet/purple which triggers an relay to power them up.
Works fine if I put the light switch on manual . Does not work in normal Auto setting of Auto/HB.
So something to overrule this of do we need An canbus8 module ?
Same for my auxilairy position lights they work now with manual Low Beam and High Beam ,I hooked them direct to the blue/green wire .( Only 1 watt each )
Working on a flash module mounted behind the BCM /GWM to indicators front & rear & my auxilairy indicators.
https://www.flashpatterns.nl/product/flits-module/
Old Mar 7, 2022 | 03:49 PM
Defendit..'s Avatar
Originally Posted by Pangea123
Thanks for your replies. It worked and they got it done. The new setup does use a loud relay. It makes a clicking sound when I engage the high beam, but I suppose I will get used to it.
That depends on the relay, I have a 40amp relay which is completly silent. ( Needed to measure if it was functioning )
Old Mar 12, 2022 | 08:45 AM
Kay jay's Avatar
5th Gear
I installed Vulkan lights - anyone can help me to located a circuit to connect an electric relay to? The idea is to have this relay activated when ignition is on or car is running.
Old Mar 12, 2022 | 09:07 AM
Kay jay's Avatar
5th Gear
As I’ll not install a winch, can we use that circuit to turn relay on/off. Question is where is the junction box B engine ?
Old Aug 16, 2023 | 12:36 PM
starbai's Avatar
Where are you guys sourcing the wiring diagrams??
Old Dec 22, 2023 | 02:19 AM
Pangea123's Avatar
Originally Posted by gurka01
Good timing I just finished installing a vision light bar in the grill of my 2020 Defender X. On the headlight connector there is an Orange/Purple wire which is a 12V high beam signal.
That is what I tapped into and it is now turned on and off by the high beams. Have it connected to an SPOD.
im interested in this product. Do you have photos or videos of what it looks like at night? I’m hoping it’s good for high speeds on rural highways. Any drawbacks to the lightbar?
Old Dec 23, 2023 | 09:11 AM
gurka01's Avatar
I can try to get some night shots within the next week or so. I use it off road and highway driving all the time, no issues and great visibility
Old Dec 24, 2023 | 02:42 AM
Pangea123's Avatar
Thank you @gurka01 ! Some shots showing low beam, high beam, and lightbar would make my life easier!! Appreciate it.
jmayzer
Jun 18, 2018 12:28 AM
primussucks
Mar 25, 2015 02:04 PM
eitydeuce
Sep 17, 2013 08:09 PM
D1scoDaz
Apr 18, 2011 06:41 AM
Mountainman
Defender
May 12, 2007 01:41 PM
