Workshop manual source
Forgive me if this is redundant, but a search didn't yield me any results...
Does anyone have a good (affordable) source to purchase/download a WorkShop Manual for our L663 Defenders? I've got a MY22 on order, but figure the 20-21 workshop manual will be the same. Found "www.easymanuals.co.uk" carrying one for download, only around $20. Not sure if its legit or if there is a different one for North American spec Defenders or all the same.
Thanks!
Thanks!
I have a 2020 and downloaded that manual. It does have NA and ROW instructions.
HOWEVER, it is a pretty poor document to work with. There is no linked table of contents or index. Within the document it will reference different sections (e.g., see 501-008) and be underlined, but they are not links. And searching for the section shows all the references and the one actual target.
If you are interested in info about your vehicle is can be useful, but its use is very cumbersome.
Hey BaconL, the manual is here: https://www.easymanuals.co.uk/produc...ual-2020-2021/.
It's $24 in pdf version. It's 12,000+ pages, and cumbersome to find anything, but I'm starting to get the hang of the organization which makes it a bit easier.
Cheers,
K
Cheers,
K
It's here for free. I recommend saving a copy because I may not host it forever.
https://landroverforums.com/forum/20...0-p400-109129/
And here is the recovery guide. I have this printed and saved in the back of mine in case I ever need a complicated tow. Should know, they're all complicated with this truck.
https://landroverforums.com/forum/at...al-1079895.pdf
