Wrapped body + wheel arches
Old Mar 11, 2025 | 09:21 AM
Carljyri's Avatar
Default Wrapped body + wheel arches
I’m curious to know if anyone has installed a wide wheel arch kit on a car that was already wrapped. My car is factory-wrapped, and I’d like to install the kit on it. However, I’m wondering — if the arches are glued onto the wrap, is there a risk that they might eventually peel off together with the wrap? Has anyone had any experience with this?
Old Mar 11, 2025 | 09:39 AM
CincyRovers's Avatar
Factory wheel arches are not glued on, they are adhered with 3M tape and an adhesion promoter. I'm not sure how well they would adhere to the wrap. I would contact your dealer or a good PPF/wrap shop and see what they say.
Old Mar 11, 2025 | 10:31 AM
tbrown's Avatar
I've got the Trophy Edition, so not factory wrapped but what I understand is an Ohio (https://www.defendersource.com/threa...n-wrap.175719/) company. Anyway, I changed my wheel archs to the wide version. Removed the old ones, cleaned the surface, used the 3M prep & adhesion promoter. They have been on for a couple of years now without any issues.
Old Mar 11, 2025 | 10:48 AM
Carljyri's Avatar
Am I understanding correctly that the arches are glued onto the wrap and stay firmly attached to it, and the wrap itself stays securely attached to the paint?
Old Mar 11, 2025 | 10:58 AM
tbrown's Avatar
Yes, there is 3M automotive double sided tape and clips that keep the archs attached.
Old Mar 11, 2025 | 11:01 AM
Arches are not glued on. They are stuck on with 3M tape & adhesion promoter, which isn't glue. It helps the tape stick better to the surface, unlike glue, which does all the bonding itself.
Old Mar 11, 2025 | 07:19 PM
Banz311's Avatar
Have hynter prestige arches on my xpel wrapped 110. Sadly has lifted in certain areas on all four arches now after 4k miles. Not sure what to do for now, but may try urban next go around when time to change out ppf
brianhdefender
Nov 6, 2024 05:34 PM
Seventh
Jun 28, 2024 05:49 PM
Retiredone
Apr 14, 2024 07:13 PM
thesoundguru
Jan 10, 2015 09:52 PM
dragonhead
Dec 17, 2006 08:11 AM
