Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Adding an amplifier to 96 RR
Old May 5, 2008 | 05:33 PM
72chevy's Avatar
Default Adding an amplifier to 96 RR
What is the best way to get the signal for inputting into an aftermarket amplifier that will go to a box with two tens? If the stock head unit had RCA outputs I'd be set, but that would be too easy.
Thanks
Old May 7, 2008 | 02:06 PM
riden686's Avatar
Default RE: Adding an amplifier to 96 RR
why not upgrade the head unit?
Old May 7, 2008 | 04:05 PM
72chevy's Avatar
I've gone back and forth on that question, but I like the idea of keeping everything clean and stock with the addition of higher quality speakers and harder hitting bass. I feel I should take advantage of having one of the rare stock Rover radios that's actually working. I guess I could add a new Alpine when the stocker does eventually bomb. Right now, I figure adding an amp and subs would be the quickest, easiest and least expensive bang for the buck.
Old May 9, 2008 | 01:52 PM
riden686's Avatar
I would call crutchfield.com or go to a local shop and find out what amps can except speaker wire instead of RCA, then use the rear speaker output for your subs, but then you have the problem of powering all of your door speakers. You can't splice RCA and running more then one speaker off of the same wire willproduce bad sound quailty. If you really wana stay stock use the box in the rear cargo door, and the amp in it and get these http://www.crutchfield.com/App/Produ...1%5d6-1%2f2%22or justsave some cash andupgrade the head unit. it was the first thing did in my 96 disco, but i like the idea of not haveing a big box in my cargo area, so i might use that last sugestion or remove one of the floding jump seats for a place for a box. good luck tell me how it goes.
Old Aug 18, 2009 | 12:42 AM
aiden's Avatar
there is a way to do it with out the after market head unit ... i did that with my 2 12's for about a year ... you can splice in to the amp in the back door then run it though a converter ... i'll get a pic of it later then ... the converter will have a rca input, run the rca's to the amp and there ya go stock head unit with subs ... ( hind site 20/20 i would get the after market head unit they look good in the land rovers and just run 2 amps one for your 10's and one for the 6.5 in the door (sorry i think this migh be an old post ... i was bored hope it helps)
Old Aug 24, 2009 | 01:03 PM
jerseymike68's Avatar
nice sources here
________
Jane
Old Sep 2, 2009 | 12:23 PM
useful information
________
Pornstar Cam
Mark G
Mar 25, 2020 01:03 PM
rangeroverhse
Jan 22, 2009 09:28 PM
Dino76
Nov 3, 2007 08:56 PM
ajh
Jul 10, 2007 08:56 PM
kay
Dec 9, 2006 03:37 AM
