Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
CD changer question
Old Jul 28, 2005 | 08:30 PM
srol86's Avatar
8th Gear
Default CD changer question
I have a 95 disco with the stock headunit. It looks like its pre-wired for a cd changer (there are some wires under the driver seat). I was wondering if a sony 10 disc changer would work?
Also, Im assuming I would have to get an adapter if i would work, any ideas on where to get one?
thanks
Old Jul 28, 2005 | 08:59 PM
mikemeyer0's Avatar
Default RE: CD changer question
http://www.roverparts.com/ProductLis...umber=AMR3053G
Old Jul 28, 2005 | 11:02 PM
srol86's Avatar
8th Gear
thanks, but i dont want to spend 600 bucks. The other changer is cheap which is why i jsut wanted to know if it will work...
Old Jul 29, 2005 | 03:12 PM
mikemeyer0's Avatar
if you had a disco II you could get a adapter to make any brand work, but with the D1 I think you can only use a factory one.
Old Jul 29, 2005 | 03:15 PM
mikemeyer0's Avatar
how much cause they are about 300 bucks for a good one then an aftermarket adapter is like 200 bucks
Old Jul 29, 2005 | 04:04 PM
srol86's Avatar
8th Gear
Well the one im looking at is a sony 10 disk. Its only 75 bucks cause the guy no longer needs it. Hence why i dont want to spend 600 on a new one when i can get an aftermarket for under a 100. But are the adapters seriously 200 bucks?
Old Jul 29, 2005 | 04:56 PM
mikemeyer0's Avatar
thats how much i have seen them for, i would just look for a factory used one then, i thought you were going brand new. I have seen used factory as cheap as 100 bucks.
Old Jul 29, 2005 | 05:00 PM
mikemeyer0's Avatar
Old Jul 29, 2005 | 05:50 PM
srol86's Avatar
8th Gear
Thanks, sorry I didnt clarify that I was looking for a used one.
Old Aug 11, 2005 | 07:13 PM
duboff's Avatar
if you are replacing one or adding one on, check on ebay. they have a few and the prices are good. you may be able to find a oem changer that is less expensive than the one you are looking at. just a thought. hope it helps. gotta love a rover. duboff
bdweix
Aug 25, 2013 02:36 PM
flyplanes5
Dec 21, 2008 10:02 PM
Rfactor
Dec 5, 2007 06:18 AM
ryant06
Dec 4, 2007 04:14 PM
usedblue
Nov 19, 2007 08:16 PM
