Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
code
Old Aug 4, 2005 | 05:27 AM
pinba1173's Avatar
Default code
I had to replace the battery in my newly purchased 96 discovery the other day. after that the radio/cd/tape player would not work. when I turn it on it says CODE. According to my owners manual there should be a five digit code that I need to enter. It also said that I could find the code "on the two cards supplied with your vehicle". There are two road recovery cards in the owners manual are these the right cards? If so where can I find the code? There is a four digit code under the vin but god only knows what that is. Any help would be great.
Old Aug 4, 2005 | 01:03 PM
teamyonex's Avatar
Default RE: code
I had a '97 Disco that I traded in a couple months back. There are indeed two radio code cards you are supposed to have. They are different than the road recovery cards. If you don't have/can't find them, you'll probably have to see a dealer, where they can look the code up for you. Good luck.
Old Aug 6, 2005 | 10:50 PM
srol86's Avatar
8th Gear
Default RE: code
Call the dealer, give them your VIN and theyll give you the code. simple as that
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
