Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Custom Sub Woofer Box enclosure In My Discovery
Old Aug 11, 2010 | 07:33 PM
MountDisco's Avatar
Default Custom Sub Woofer Box enclosure In My Discovery
It took me a bit of time, but I thought I did pretty well for my box. It took me about 2 hours in my barn, then covered it with the closest color I could find.
I just used my old stuff from another car, 2 12" JBL's 600w and a 1100w amp. I made it a ported box.
I had to put sooo much stuffing in it and would not recomend trying 2 12's again. If I could do it over, i would have used 2 10's.
I have another disco now, and not sure how my next one should look. Should I do it the same way, or mount it on the back door? (since its hollow)
I built this when i was a freshman in college so go easy please
All FEED BACK PLEASE!!!!
Attached Thumbnails Custom Sub Woofer Box enclosure In My Discovery-hpim2732.jpg   Custom Sub Woofer Box enclosure In My Discovery-hpim2734.jpg
Old Aug 13, 2010 | 11:29 PM
Rover Chris's Avatar
not bad, but I am sure the air space is way off, taking out the stuffing would be a good idea as you don't want a lot in there, also ported boxes require alot more air space so converting it to sealed may be a thought, if you want to figure out the airspace use this calculation L X W X H in inches, then divide that total by 1728 and that will give you the airspace, if you have a slant (looks like the top may be) then measure the highest point and the lowest point add them together and divide by 2 to get that part of the equation. hope this helps
aarongregor
Nov 21, 2012 04:08 PM
4x4ron
Feb 12, 2012 10:52 AM
WaltNYC
Sep 26, 2011 10:35 AM
thebiglad
Mar 14, 2008 09:15 AM
Captain Ducman
Jun 5, 2007 02:08 PM
