Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Got 2 questions
Old May 19, 2006 | 07:44 AM
CronicJoeBlunt's Avatar
Default Got 2 questions
First one is, I noticed that the control wire for the cd changer (clarion, I think) in my 95 4.0 SE seems to be the same as the one from my 94 RR county (pioneer), does this mean I could interchange them? Cause the Pioneer one never skipped, even when off-road and the other one Skips way too much. Second question is, does anyone know if the audio leads that goto the sub are High level or low level? I want to tap into them and run them to my own sub box/amp and not sure if I can run them into the low level inputs or if I need to go through a high to low level converter then to my amp etc.....
Old Jun 4, 2006 | 05:14 PM
Landdaddy's Avatar
Default RE: Got 2 questions
ORIGINAL: CronicJoeBlunt
I can try to answer one of your questions> I would run your own wiring for your sound system leaving the old intact for in case someday you do sell it and want to put the old back in. Then I had my system done, I made sure that everything that was there was left but hidden, that way if they pull my Rover from my dead cold hands, they can put it back to the original.
Just a thought.
glassman66
Jul 7, 2012 03:10 PM
Analogkid
Oct 28, 2010 05:38 PM
lipadj46
Sep 12, 2009 07:31 AM
Disco2Fever
Oct 19, 2008 08:05 PM
silence
Aug 20, 2005 10:54 AM
