Cargo Door Fold down table/plating
Old Jun 16, 2017 | 04:20 PM
ccraft18's Avatar
Default Cargo Door Fold down table/plating
Im thinking about removing the interior paneling from the rear cargo door, and going with a diamond plating panel along with a fold down utility table... any ideas on how I should start? Im assuming most people just remove the panel and sort of trace everything to get the proper fit. Any know of any build guides, or have any advice?
Old Jun 16, 2017 | 10:44 PM
acg's Avatar
acg
This is how mine is done. Use Rivenuts for mounting the diamond plate. Sourced a couple grab-handles from the wrecker yard and mounted them above the table (also using Rivenut for mounting).
Attached Thumbnails Cargo Door Fold down table/plating-table1.jpg   Cargo Door Fold down table/plating-table6.jpg   Cargo Door Fold down table/plating-table5.jpg
Old Jun 16, 2017 | 10:48 PM
acg's Avatar
acg
I used a metal cable for holding the table. In hindisght, I should have used a non-metallic rope or canvas strap (to prevent rattling when off-roading).
Wing nuts were used.
I also used rubber bumpers to cushion the diamond plates to prevent rattling.
Attached Thumbnails Cargo Door Fold down table/plating-table6.jpg   Cargo Door Fold down table/plating-table3.jpg
Old Jun 16, 2017 | 11:25 PM
acg's Avatar
acg
Smittybilt i-Rack (spare tire mount) to hold the propane tank. This give easy propane access to the cargo fold down table.
I-Rack 2 - Smittybilt
The iRack also holds a Smittybilt jerry can holder, my Scepter water can and Thule bike carrier.
Attached Thumbnails Cargo Door Fold down table/plating-table7_license_plate_covered.jpg   Cargo Door Fold down table/plating-16.jpg
Old Jun 18, 2017 | 01:16 PM
TOM R's Avatar
Depending on the type of wheeling u do, its been my experience thus far with my rover,weight or things sticking off the *** end is a bad idea , when u come down off a ledge its a lot of down force momentum if u understand what I'm describing
If u just flat land then go for it
Old Jun 18, 2017 | 05:32 PM
fishEH's Avatar
Unless you plan on walking on your cargo door I'd skip the diamond plate and go with aluminun and save some weight.
filbs
Jun 13, 2012 03:03 PM
DiscoKline
Jan 26, 2012 11:29 AM
PatchesDef90
Oct 21, 2010 05:10 PM
County95
Mar 7, 2007 02:21 AM
