Her name is Majesty
Old Feb 24, 2018 | 05:50 PM
TRIARII's Avatar
Default Her name is Majesty
2004 D2
213,000
Rust free
Rebuilt motor (supposedly)
Pearl White finish
Bone stock
This is a gamble. The journey begins anew.
Seller pic
Seller pic
Day 1: Arrival
Day 1: Arrival
Day 1: Arrival
Day 1: Arrival
Day 1: Arrival
Day 1: Arrival
Solid rust free chassis
Old Feb 24, 2018 | 05:59 PM
stillruns's Avatar
It has good bones. That's all that matters. Congrats!
Old Feb 24, 2018 | 07:10 PM
Friday Night Disco's Avatar
I only care about what is behind your truck on that trailer!! Please tell me more about that!
Old Feb 25, 2018 | 05:37 AM
The Deputy's Avatar
Looked at this rig for a while on craigs, even thought about pulling the trigger on it for a bit. Then saw you were looking at it and passed. Hope it works out for you.
Me, l would have named it "old whitey".
Looking forward to following along.
Brian.
Old Feb 25, 2018 | 09:26 PM
coop74's Avatar
On another forum i am on the truck with the two loaded on the rear was shown and they were wondering who it belonged to... now i know!
Old Mar 1, 2018 | 07:36 PM
TRIARII's Avatar
Going through new truck and figuring out what loose ends need fixing. Im fortunate to have access to a spare parts truck.
Factory front driveshaft with worn u-joints
Worn power steering hoses
Radiator with broken nipple and a half *** fix resulting in a coolant leak
Cracked windshield cowl trim
Old Mar 2, 2018 | 09:45 PM
coop74's Avatar
Not sure if this is a fluke but the negative cable grounding point is loose in the image that shows it above.
Old Mar 3, 2018 | 03:08 AM
The Deputy's Avatar
Snap some pictures of the frame when you get a chance. Just looking at the steering shaft in the last picture, looks rust free. Mind looks like it's spent the better part of its life with Charlie's Tuna.
All of those issues look pretty minor and easy fixes, especially since you have a spare rig. Good eye though, because these are minor issues that can turn into big ones if gone unchecked.
Looking forward to seeing it's transformation.
Brian.
Old Mar 3, 2018 | 02:10 PM
TRIARII's Avatar
Its been a busy week and things are coming along gradually. I made some revisions. Swapped over the Tom Woods front drive shaft, alternator, airbox assembly & MAF sensor and fixed the ground to the battery. Next I swapped over all 5 wheels and tires, its a very tight fit but no rubbing as far as I can tell. Still need to replace the radiator and I want to flush the cooling system and run some distilled water for a cycle.
Also need a upfront o2 sensor and possibly an abs sensor for one of the front wheels. Im getting one of those gear ratio monitoring (4th) faults. The truck feels solid but when I hit speeds above 30 mph it feels like the transmission is not changing gears like it should, consequently the rpm meter gradually soars the longer you maintain pressure on the accelerator. Im going to do a fluid and filter change on the transmission to see if that smooths things out.
Swapped over the 235/85/16 BFG KO2's; stock suspension and no rubbing!
Old Mar 4, 2018 | 05:07 AM
The Deputy's Avatar
Making nice headway.
