my 98 disco1
Old 03-10-2014, 08:33 PM
TOM R's Avatar
Made new cargo door panel 14 gauge alum.
  #192
Old 03-11-2014, 07:13 AM
TOM R's Avatar
CB mounted, wired into power for rear mirror ground to common in same area, 20' of radio shack coax run in roof to back then through rubber boot into cargo door ( lots of lube use a fish cable) unibit to cut hole , grommet and hook up, home made antennea bracket, total cost under $25 had most laying around.
The CB bracket is nut and bolted with fender washers to the plastic, ran all wires through existing hole above sun visor, poked hole in headliner for coax, nipped a bit of plastic webbing to run wires in the ceiling console.
Put a loop in the coax after exiting door so water drips off
  #193
Old 03-11-2014, 08:08 AM
TOM R's Avatar
I think this location only will work with a real small CB because of weight
  #194
Old 03-11-2014, 09:56 AM
wrongway1's Avatar
Looks great! I was thinking about the same location. How did you route your cable to the CB? It looks like you hid it pretty good.
  #195
Old 03-11-2014, 08:34 PM
TOM R's Avatar
Up through existing hole in ceiling console, punched hole in headliner then ran in headliner to rear , dropped down by tail light and through boot into cargo door
  #196
Old 03-12-2014, 08:19 AM
wrongway1's Avatar
Thanks, I will be able to use most of that route, but I have my antenna mounted on the rack. I was thinking the headliner was attached to the roof ribs making that a pretty difficult task.
  #197
Old 03-12-2014, 02:56 PM
TOM R's Avatar
Nope remove front ceiling console, a pillar cover, both grab handles and you can get in there enough to run it, there is a ledge in the roof the wiring on pass side runs down , you will have a slight issue when you get to the vista window at c pillar but it is doable
  #198
Old 04-04-2014, 07:20 PM
TOM R's Avatar
Got another section of my cargo area diamond plated today, now there is a small shelf I can actaly attach something light to
  #199
Old 04-06-2014, 12:02 PM
TOM R's Avatar
Finally got the rear cones installed, made upper retainers from some galvanized laying around 6" long 1/4" thick 1 1/2" wide, bolts are 3/8" x 2 1/2 with washers and nyloc nuts, holes in bottom plates are 3/8" hole in top plates Are 3/8" and 1/2" this allows wiggle room to drop the second upper bolt from top on angle, holes drilled 1 3/8" in from end
We also removed the brake line bracket from rear it was pulling hard on the hoses at full droop, probly make short extension brackets
  #200
Old 04-07-2014, 06:58 AM
TOM R's Avatar
Default adjust your ***** !!!
Wow finally drove her after the swivel adjustment and it is like a new rig steering is perfect tight, no more wheel jump/ wobble when I hit bumps in the road it is super easy just do it
Only downside the ball seals were starting to weep, now they leak but I noticed rust on the drivers ball, am sure pass is the same looks like she sat somewhere a long time by the rust mark
Quick Reply: my 98 disco1
