my 98 disco1
Old 07-02-2014, 02:05 PM
TOM R's Avatar
Added a sheet of expanded aluminum 1/2" diamonds to keep stuff from falling onto roof
Got some 3/4" galvinized split ring pipe mounts to mount quick fists
  #252
Old 07-05-2014, 12:15 PM
TOM R's Avatar
OK here is some preliminary bumper work, 2" box 1/8" wall this is (1) 10' stick not including where we cut off the ends, we still plan to add ends that go back to protect the front lower fender, I also wat to plate the top and eventually we will build a brush guard from tubing
Reglued mesh on grill with 2 part fast set plastic weld epoxy from Lowes it is a paste dries amber in color will see how it holds up
  #253
Old 07-05-2014, 12:20 PM
TOM R's Avatar
I need to mount front license plate , choices are weld tabs to bumper or drill into skid, thoughts?
  #254
Old 07-05-2014, 02:54 PM
HammerFit's Avatar
Hope it holds. I Learned a lesson about cure times of the epoxies. Let it setup.
  #255
Old 07-13-2014, 05:54 PM
TOM R's Avatar
installed a d2 rear power outlet in the pass D pillar below the speaker, power and ground right there
  #256
Old 07-13-2014, 06:29 PM
ihscouts's Avatar
Looks factory.
  #257
Old 07-13-2014, 08:31 PM
TOM R's Avatar
thanks, it is from a d2, there is plenty of room behind there for the depth of that socket, ground stud right there and gonna use the switched power for the trailer harness as i will not be installing a 6 or 7 way trailer plug, the wire i am tapping is purple just like the one on this socket, it is a lighted socket undecided if I want to make that work too
just traced it on the pannel and cut the hole smaller with a dremel, cut and bent a piece of sheetmetal as a strap across the back put a hole in it and reused the d2 mount screw with speed clip
it would have fit centered under the speaker but if I wire the rear work lite ont he roof rack I may put the switch next to this one
  #258
Old 07-13-2014, 08:50 PM
MM3846's Avatar
is that a 12V outlet?
  #259
Old 07-13-2014, 09:40 PM
TOM R's Avatar
Yes, d2 have em in the cargo area
  #260
Old 07-13-2014, 10:53 PM
fishEH's Avatar
Sweet! I have one of those in my parts bin.
Quick Reply: my 98 disco1
