Pimpin' my ride
I have this truck already two years and it was neglected , because I also have 2001 d2.So now I decided to fix it a bit because I really like how it drives.I know there is some rust but this doesn't bother me , frame is solid.
Isuzu Trooper you see in the background will be used for parts.
![Name: trooper004.jpg
Size: 173.1 KB](https://landroverforums.com/forum/attachments/build-threads-43/47317d1501386726-pimpin-my-ride-trooper004.jpg)
![Name: trooper006.jpg
Size: 172.8 KB](https://landroverforums.com/forum/attachments/build-threads-43/47318d1501386726-pimpin-my-ride-trooper006.jpg)
![Name: landrover003.jpg
Size: 338.1 KB](https://landroverforums.com/forum/attachments/build-threads-43/47319d1501386726-pimpin-my-ride-landrover003.jpg)
First thing was to remove all carpets and padding and repair the rust.
You can see what I found under the carpet.Drivers side floor is totally shoot.
![Name: may2010023.jpg
Size: 179.2 KB](https://landroverforums.com/forum/attachments/build-threads-43/47313d1501386726-pimpin-my-ride-may2010023.jpg)
Passengers side is bit better but only rust is holding the floor.This floor will go too.
![Name: may2010024.jpg
Size: 194.1 KB](https://landroverforums.com/forum/attachments/build-threads-43/47314d1501386726-pimpin-my-ride-may2010024.jpg)
More I look more I find.
![Name: may2010026.jpg
Size: 126.5 KB](https://landroverforums.com/forum/attachments/build-threads-43/47315d1501386726-pimpin-my-ride-may2010026.jpg)
While removing drivers side floor I damaged the brake line.Brake line was attached to the floor.
![Name: may2010028.jpg
Size: 184.9 KB](https://landroverforums.com/forum/attachments/build-threads-43/47316d1501386726-pimpin-my-ride-may2010028.jpg)
That's it.Looks like I will have to open everything.Rust on the top of the A pillar
![Name: jun2010011.jpg
Size: 119.2 KB](https://landroverforums.com/forum/attachments/build-threads-43/47308d1501386726-pimpin-my-ride-jun2010011.jpg)
Broken down spout line.
![Name: jun2010010.jpg
Size: 83.2 KB](https://landroverforums.com/forum/attachments/build-threads-43/47309d1501386726-pimpin-my-ride-jun2010010.jpg)
These is my trunk floor.
![Name: jun2010027.jpg
Size: 206.1 KB](https://landroverforums.com/forum/attachments/build-threads-43/47310d1501386726-pimpin-my-ride-jun2010027.jpg)
Frame is rusted but solid.
![Name: jun2010009.jpg
Size: 188.3 KB](https://landroverforums.com/forum/attachments/build-threads-43/47311d1501386726-pimpin-my-ride-jun2010009.jpg)
I already repaired fuel pump.Connectors were rusted and started to leak gas.I replace them with pieces made from gas line, also fuel level wire was broken so I fixed that also.
![Name: jun2010003.jpg
Size: 173.4 KB](https://landroverforums.com/forum/attachments/build-threads-43/47312d1501386726-pimpin-my-ride-jun2010003.jpg)
To repair my brake lines I decided to ditch ABS , it never worked anyways.
So I went from this.....
![Name: ABS.jpg
Size: 96.2 KB](https://landroverforums.com/forum/attachments/build-threads-43/47293d1501386694-pimpin-my-ride-abs.jpg)
to this
![Name: NOABS.jpg
Size: 73.1 KB](https://landroverforums.com/forum/attachments/build-threads-43/47294d1501386694-pimpin-my-ride-noabs.jpg)
This is how it looks like without modulator.
![Name: jun2010007.jpg
Size: 179.6 KB](https://landroverforums.com/forum/attachments/build-threads-43/47295d1501386694-pimpin-my-ride-jun2010007.jpg)
This thing goes in garbage .Believe it or not new one cost 2500$![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
![Name: jun2010020.jpg
Size: 119.2 KB](https://landroverforums.com/forum/attachments/build-threads-43/47296d1501386694-pimpin-my-ride-jun2010020.jpg)
This is my new simple brake line.
![Name: jun2010006.jpg
Size: 184.8 KB](https://landroverforums.com/forum/attachments/build-threads-43/47297d1501386694-pimpin-my-ride-jun2010006.jpg)
![Name: jun2010005.jpg
Size: 159.3 KB](https://landroverforums.com/forum/attachments/build-threads-43/47298d1501386694-pimpin-my-ride-jun2010005.jpg)
I built new bracket to hold brake line , old one was supported by trunk floor.
![Name: jun2010002.jpg
Size: 194.4 KB](https://landroverforums.com/forum/attachments/build-threads-43/47299d1501386694-pimpin-my-ride-jun2010002.jpg)
![Name: jun2010017.jpg
Size: 202.6 KB](https://landroverforums.com/forum/attachments/build-threads-43/47300d1501386694-pimpin-my-ride-jun2010017.jpg)
For new members this is where fuel filter is located.
![Name: ABS.jpg
to this
![Name: NOABS.jpg
![Name: jun2010001.jpg
Size: 171.3 KB](https://landroverforums.com/forum/attachments/build-threads-43/47301d1501386694-pimpin-my-ride-jun2010001.jpg)
I'll be following your pimping with great interest.
My advice is to paint all exposed areas with POR 15 paint. It really likes to bond to rusted surfaces, just a lot pricey, like $60 a liter but worth it every dollar.
POR15.ca is near Montreal, check their site. I purchased the "starter kit" and am painting wherever there is a rust issue to stop rust.
Please note that if you get it on your fingers, you have to remove it before it dries or wait untill it wears off.
SD
SD
on
After seeing yours, I am glad my 97 DI is minimal rust in comparison.
I am interested in your brake mod. So you basically just removed the Wabco ABS modulator and replumbed the rest? No other new parts except the new brake lines?
I just replaced my fuel lines from the tank to the engine bay. A 25 foot coil of steel tubing for about $22. I tried to replace the inlet and outlet lines to the fuel pump housing but was not successful, so I bought a new unit from Rovers North for about $105.00.
Does anyone want the old one I removed? The pump and sender are good. If anyone needs it let me know, you would have to use a different top piece, so if you have one with a bad pump but a good top piece, it would work for you.
I am cleaning out my garage so if anyone wants the old fuel pump, let me know before I throw it away. You can have it for $30 to cover USPS flate rate shipping to get it to you. PM me if you want it.
Well I took part of the floor with seat mounting from the Isuzu Trooper.This truck was owned by my father in-law.Great truck but rust eat it away.Surprisingly body is better than frame.He wanted to scrap it , than I decided to take it for parts.
![Name: jun122010002.jpg
Size: 156.1 KB](https://landroverforums.com/forum/attachments/build-threads-43/47267d1501386669-pimpin-my-ride-jun122010002.jpg)
This is test fitting the Isuzu Trooper floor to Discovery .
![Name: jun122010003.jpg
Size: 124.7 KB](https://landroverforums.com/forum/attachments/build-threads-43/47268d1501386669-pimpin-my-ride-jun122010003.jpg)
This is Isuzu Trooper passengers side before cutting.There is heating unite under the seat.
![Name: jun122010001.jpg
Size: 137.9 KB](https://landroverforums.com/forum/attachments/build-threads-43/47269d1501386669-pimpin-my-ride-jun122010001.jpg)
Test fitting the floor and the seat , noting is welded yet.Interesting thing with Isuzu Trooper driver seat is , it can be adjusted not just forward reverse but up and down.It can be moved up to 2 inches.Somebody on this forum asked about it and answer is yes everything is possible.I didn't pick these seats because of these height adjustments , I pick them because I have them for free.
![Name: jun122010004.jpg
Size: 124.0 KB](https://landroverforums.com/forum/attachments/build-threads-43/47270d1501386669-pimpin-my-ride-jun122010004.jpg)
Actually I have these Toyota Tercel seats that I like more than Trooper's,( I got them for free also) somewhere in the future I am planing to install them. Here you can see Toyota Tercel seat next to original Discovery seat.
![Name: jun2010026.jpg
Size: 199.3 KB](https://landroverforums.com/forum/attachments/build-threads-43/47271d1501386669-pimpin-my-ride-jun2010026.jpg)
Seat support is tacked in.
![Name: jun122010005.jpg
Size: 118.3 KB](https://landroverforums.com/forum/attachments/build-threads-43/47272d1501386669-pimpin-my-ride-jun122010005.jpg)
Seat installed in permanent position.
![Name: jun122010007.jpg
Size: 113.1 KB](https://landroverforums.com/forum/attachments/build-threads-43/47273d1501386669-pimpin-my-ride-jun122010007.jpg)
Floor is part of the cargo floor from Isuzu Trooper.
![Name: jun122010009.jpg
Size: 119.7 KB](https://landroverforums.com/forum/attachments/build-threads-43/47274d1501386669-pimpin-my-ride-jun122010009.jpg)
I caulked it.
![Name: jun122010010.jpg
Size: 103.7 KB](https://landroverforums.com/forum/attachments/build-threads-43/47275d1501386669-pimpin-my-ride-jun122010010.jpg)
Painted.
![Name: jun122010016.jpg
Size: 113.5 KB](https://landroverforums.com/forum/attachments/build-threads-43/47276d1501386669-pimpin-my-ride-jun122010016.jpg)
Passenger area test fit.Those 2x3 you see are to measure level of the seats supports towards the frame.Should be parallel.
![Name: jun122010015.jpg
Size: 122.2 KB](https://landroverforums.com/forum/attachments/build-threads-43/47277d1501386669-pimpin-my-ride-jun122010015.jpg)
Test fit the passengers seat and support.Not welded yet.
![Name: jun122010014.jpg
Size: 107.7 KB](https://landroverforums.com/forum/attachments/build-threads-43/47278d1501386669-pimpin-my-ride-jun122010014.jpg)
Look from the back.
![Name: jun122010013.jpg
Size: 108.3 KB](https://landroverforums.com/forum/attachments/build-threads-43/47279d1501386669-pimpin-my-ride-jun122010013.jpg)
Now at this point I came to the snag.Maybe it is good idea to change my fuel lines while everything is open.Does anybody have any pics of how to do it?
I caulked it.
Painted.
Look from the back.
