Super Model With Bad Crack Habit Rehab Build-
Old Nov 1, 2016 | 07:32 PM
  #611
I dig it looks good man way to knock it out.
Old Nov 1, 2016 | 07:39 PM
  #612
Shiftonthefly1's Avatar
I really love the way it came out. I'll take one please and thank you.
Old Nov 5, 2016 | 06:59 PM
  #613
Detoured Discovey's Avatar
Loosing the front bumper and plastic...........MIND BLOWING effect on engine temps.........it's f'ing crazy!!!
Old Nov 5, 2016 | 08:22 PM
  #614
Airflow has been known to help.
Old Nov 6, 2016 | 08:07 AM
  #615
Wasn't there a video about that very thing from St Pierre? He was in "the bush" and mounted his front license plate just slightly over a bumper opening. He immediately noticed and increase in temps. He moved or notched it or something back to normal. Maybe a half inch over the hole made a big difference. I can imagine what gains your getting with the hood vents and the bumper ditched. I've got a Saudi grill and I see a huge difference. I'm seriously considering those hood vents. It rains less than 5" a year here. So I'm not worried about incoming water.
Old Nov 6, 2016 | 09:53 AM
  #616
Lowcoe's Avatar
Hello, new to the board. Probably an intro page somewhere I should have filled out first. My neighbor has a 93 disco making her mark in his driveway. He's been wanting to sell it for about a year now. Second owner. First owner reported that engine was replaced at 90k. It's sitting at 120k now. Lots of deferred maintenance by the looks of it, but it's never left him stranded. Brakes are soft, stops not swift. Anyways I've read your whole thread in the last two days in an effort to talk myself out of it.. Really enjoyed the thread.. still on the fence. Asking price is 3500... California car.. need to go back and look for rot... need to get my project pickup running before I sell my daily driver pickup because as soon as you have no pickup you need a fridge or a couch or something... again, many thanks. I'll let you know if I learned any lessons from your cautionary tail. Or if I just took the dumbass route like I usually do in life.....
Old Nov 6, 2016 | 11:58 AM
  #617
Lowcoe's Avatar
Wait not 93. 2003. Sorry
Old Nov 6, 2016 | 04:22 PM
  #618
Many thoughts on the grill 'shifty....there's more closed surface area then open, your conversion is probably called that for a reason.......it's HOT there and makes more sense! I'm sure you see much better temps! As far as hood vents, proper placement is key........I have ZERO side effects from rain.
Locoe......if your board with life and need an adventure......GO FOR IT!
$3500 is far too high, offer him/them 2k at best.......they'll need 2k one day over letting it sit in the driveway dripping. Thanks for reading!
Almost pulled the rear bumper this afternoon..........fired off my generator for a system check prior to winter instead......glad I did as she ran a tad rough for the first 5 minutes......also winterized every other gasoline powered tool I owned as well........that was 2 hours better spent!!! Giddy Up!!!
Old Nov 6, 2016 | 04:47 PM
  #619
Lowcoe's Avatar
Good advice! If nothing else it motivated me to finish up repairs on one more fender and get it into primer... sorry to hijack da thread again. I will sit back and watch from here on out unless I have something on topic to add... carry on!
Ohh oo.... thought of a question! When welding on a complete rig such as yours don't you have to worry about frying the ECM or other electronics??? Ok I'll go sit back down in the back of the classroom. Carry on!!
Attached Thumbnails Super Model With Bad Crack Habit Rehab Build--img_9523.jpg
Old Nov 6, 2016 | 05:50 PM
  #620
ihscouts's Avatar
Not if you disconnect the battery terminals....... and if your really paranoid disconnect the ECM and pull fuses. Common shop welding practices when welding around electrical/electronics.......
As for the 03 DII, I wouldn't, sorry to be the rain cloud in the sunshine parade. It's the runt of the LR litter right after any Freelander. Read up in the Disco II section. The 03/04 are problematic more over than the run of the mill 99 1/2 - 02 Series II Discovery's and you'll notice that most of the posts on this board are in that section.....frig'n station wagons who wanna be Rovers. Busted gear-rotor oil pumps, cracked blocks, liners not sealing, liners slipping, cams drifting out of their bearings and a myriad of other poor quality controls those models suffered. There is a huge difference between the Disco dances. 94-95 came with a distributor and FI. 96-99 1/2 had a crank sensor = Sequential FI and then the DII which was more car-like instead of truck like. You'll never bust a lug stud on an early Disco...... ever. Find an early 97 and you'll be happy, the late 97 on up had a funkiness in the fuel vapor handling that frankly has wires tied in series to all kinds of junk.
