Super Model With Bad Crack Habit Rehab Build-
#962
Since 1984, a bank has held paper on only 2 of the..........60 plus vehicles I've owned/bought/traded....(16 were Jeeps).......It got so bad I bought N. Carolina dealer plates thru a friend, of a friend.......of a friend for 3 years...
Out of those many, the question is, how many do I wish I kept???...lol !@!
The 'Binder would have been one of them..........
Anywhoooo.......Switch is ordered!!!!
Now I need to order rear calipers...............E Brake works good for now, so no real hurry......HAA HAA HAAAA, LUCAS DID'NT DO CABLE WORK!!!!
#964
Switch showed up, quick investigation yesterday tells me the steering wheel needs to come off......I swear these vehicles were engineered by idiots.....Oh and I have a 1/2 baked electrical connection.....thank you Mr. Lucas..
#965
#966
You got THAT right Army, a fuse is supposed to protect the system when a switch fails......obviously Lucas/Rover disagree's with this.....
So I bought a used switch off ebay, $38 bucks shipped, in nice condition.
It's suggested the steering wheel needs to be removed....probably so the service guy can charge you more......it doesn't...
Remove cover to expose switch, and the 2 screws which need to come out.
Turn the TOP of your steering wheel to the 9 o'clock position...
For even better access, remove air bag (2 screws)....you can now unscrew the 2 small retaining screws-
Once screws are removed, get a flat head screw driver and wedge between the retainer and the switch, now simply pull the switch towards you and remove, then remove the 2 wire connection.......reverse to reinstall.
So in the end, the switch was in fact bad and all of the trucks lighting is once again working........So I think this my 3rd electrical/switch connection I've found burned with a failed electrical component......but never a bad fuse, kind of scary if you think about it....
#967
#970
Haven't had a warm enough day to do the rear calipers since they showed up....actually just got a fresh 25" of snow..........But it was warm enough to pull the head lights and go full Eurotrash....lol!!!
In even worse newz.....proving I am in fact an idiot......this may be in my driveway soon......Note the hood in it's intended position.......
