Too many D1's
Old Dec 20, 2014 | 10:04 PM
  #81
fishEH's Avatar
So November was ridiculously cold and I didn't do squat. December had been a little better.
I Plasti-dipped my Fox and replaced the heims with urethane bushings.
Finally fired up my welder and started practicing. My first one is on the right and a later one on the left. Going to keep practicing before I start in on suspension components.
And I pulled my rear diff tonight to check and possibly rebuild. The drain plug square hole was more of a diamond shape from dragging it on rocks so draining it beforehand wasn't possible. Yum!! LOL
Old Dec 20, 2014 | 10:26 PM
  #82
jafir's Avatar
You've got a welder.... Weld something to that plug and pull it out.
Old Dec 20, 2014 | 11:07 PM
  #83
fishEH's Avatar
That's a good point! I would probably do that except the axle housing from my '98 is getting scrapped. I actually already cut off one of the trailing arm mounts because of a seized bolt.
The rebuilt '95 housing will receive a new magnetic drain plug and a piece of DOM welded around it as a guard.
Old Dec 21, 2014 | 09:30 AM
  #84
TOM R's Avatar
Originally Posted by MM3846
i'd rather have that than my rubbermaid shed and gravel driveway!
We do everything in a stone driveway, dads 2.5 car garage has 3 vehicles in it plus all the tools and equipt, cant walk around them
Old Dec 22, 2014 | 08:03 AM
  #85
CUpgt's Avatar
The garage at the new house is the best thing that has happened to me when it comes to wrenching...but the Disco doesn't fit in the garage. Lol. Concrete driveway beats grass or gravel though.
Old Dec 22, 2014 | 12:00 PM
  #86
fishEH's Avatar
Find a set of cheap wheels and roll it in the garage sans tires!
I am thankful I have a concrete drive to work on. My side drive is gravel and working on things over there is a major pain in the ***.
Old Jan 20, 2015 | 01:13 PM
  #87
fishEH's Avatar
Haven't done squat in a long time. Holidays, work, ice fishing, home repairs, blah......
Today I ordered a pair of these from Ballistic.
Weld-In Fill Plug
Originally I was going to drill and tap my sewer caps, but the cost of the bit and tap was adding up fast. It was actually cheaper to just buy the bungs.
Now to decide how high to weld in the plug and if I want to run wet hubs or not....
Old Jan 24, 2015 | 09:06 PM
  #88
fishEH's Avatar
Mocked up the sewer cap for the rear diff today.
Need to drill a hole for the fill bung, weld it in, and weld the cap on.
Old Jan 24, 2015 | 10:12 PM
  #89
jfmartin25's Avatar
Subscribed! This is cool! I want to do a heavy duty off-road build on an LR3!
Old Jan 30, 2015 | 01:53 PM
  #90
fishEH's Avatar
Little more on my rear diff cover today. Drilled the hole for the full bung/plug. Utilized the Bandsaw at work to trim about 3/8" off the cap. This will let it sit closer and hopefully clear the fuel tank on suspension compression.
