Defender Talk about the Land Rover Defender within.
110 nothing out of the distributor
Old Oct 31, 2012 | 11:02 AM
Manual Life's Avatar
5th Gear
Default 110 nothing out of the distributor
I have a 93 110 that will no longer start and I am at a loss as to what the problem is.
I have spark into the distributor but not out. I replaced the cap and rotor and nothing changed. I tested the amplifier and Ohlmed out the pick up and it checks out as well. Amplifier has proper ground, I attached an additional one just to make sure.
Also, I have swapped out the current distributor with a known good one and meet with the same result of no spark out. With cap off the rotor does turn when cranking. New battery. I wondered about the ignition tumbler being part of the issue but since the coil gets spark I ruled that out.
Suggestions or ideas?
Old Oct 31, 2012 | 11:45 AM
Coil wire to center of distributor? Can you attach a spare spark plug to it and see it spark?
Old Oct 31, 2012 | 03:21 PM
5th Gear
Yes, it checks out. It's not the most brilliant spark. I'm getting 12.3V to coil, which is new, from a battery at 12.42V.
Cranking the voltage ranges from 9.3-10.4V.
Old Nov 2, 2012 | 07:00 PM
jafir's Avatar
I've seen the amplifier test good but still be bad on my buddy's old range rover classic.
Old Nov 5, 2012 | 04:45 PM
5th Gear
Understood. But am I mistaken that ultimately all the amplifier does is send a signal back to the coil to tell it to fire? (And coil does fire)
If that is not it's job and it's faulty I'll be packaging up the new distributor.
NCLR
Nov 7, 2014 05:14 PM
dms98e
May 29, 2008 11:50 AM
motormikeyman
Apr 22, 2008 06:54 PM
mestupstud
Nov 10, 2007 07:49 AM
Ex CCS Racer
Tires
Oct 21, 2007 08:36 PM
