Defender Talk about the Land Rover Defender within.
1997 Defender 90 Engine
Old Jul 6, 2024 | 08:30 AM
97Defender90's Avatar
Default 1997 Defender 90 Engine
Hello everyone
I am new into Land Rover ownership and have a 97 Defender 90 that needs an engine, my question is, can I use a 3.9L engine that was used until 1995 in my 1997 Defender 90 to replace the 4.0L engine? I can buy a remanufactured 3.9L engine reasonably for the swap. Thank you for helping.
Old Jul 6, 2024 | 01:42 PM
The Deputy's Avatar
Quick search...not exactly your year or model, but enough info to say there is quite a difference between the 3.9L mechanical distributer and 4.0L OBD electronic.
https://www.landroversonly.com/threa...-engine.47367/
https://www.rangerovers.net/threads/...ith-3-9.21152/
Doesn't seem to be direct swap, a lot of change over...from what l've read.
What is wrong with your 4.0? Don't know where you are located, but D&D Fabricating, in Almont, Michigan rebuilds land rover engine exclusively.
Home
The only person l know, that may be able to answer your question would be Chris Ray...goes by Mud Ruts on several different boards. Very knowledgeable.
https://www.landroversonly.com/threa...in-ohio.37269/
Or talk to Eric at...
https://www.lrshops.com/ohio/trailhead-4x4-off-road
Good luck, wish l had more to offer.
d90II
Jan 23, 2023 11:11 PM
V8DEFENDER90EUROPE
Defender
Jan 14, 2023 11:23 PM
paulradley
Dec 24, 2007 10:16 AM
trini defender
Defender
Dec 26, 2006 11:40 PM
