Defender Talk about the Land Rover Defender within.
19J/12J DPS run/stop solenoid question
Old Oct 9, 2019 | 02:54 PM
Statueman's Avatar
Default 19J/12J DPS run/stop solenoid question
Greetings. I have a 1980 Santana Ligero that came with a 2.25 diesel. I recently started swapping to a 19J 2.5 TD. Unfortunately the turbo on the 19J won't clear the upper steering arm so I removed it making it a 2.5 NA 12J (sort of). I'm now ready to start it BUT my original truck has no wire for the DPS run/stop solenoid.
My questions are: is the DPS run/stop solenoid wired to the ignition on a 2.5TD and can I run a wire from the run position on the ignition to the run/stop solenoid using the original 2.25D ignition? OR must I switch out the ignition to a later Defender ignition? Can it be wired from another source and! if so, where?
Remember that the 2.25D shuts off with the choke cable. As I haven't access to another 2.5TD equipped vehicle I have no frame of reference on how this run/stop solenoid should be wire nor how a Defender ignition is wired.
Thanks for any assistance.
nickcashmere
Oct 9, 2023 09:55 AM
Dave Haynes
Defender
May 2, 2019 01:54 AM
MonteroMan
Dec 28, 2014 10:54 PM
Mountainman
Defender
Jul 27, 2007 06:54 AM
suveer
Jun 13, 2007 12:36 AM
