Defender Talk about the Land Rover Defender within.
200Tdi timing problem - major headache, help needed urgently
Old Oct 10, 2008 | 04:07 PM
mandythelandy's Avatar
Default 200Tdi timing problem - major headache, help needed urgently
Ive got major headache with my 200tdi. Just replaced timing belt as snapped. Reset the injection timing as it should be, lined up the crankshaft and camshaft as they should be, per Land Rover workshop manual. When put bakc together it will just about start after a couple of turns (maybe 4 or 5), but then runs really rough almost like fuel staved. No response at all on the throttle. Engine almost lollops if you know what I mean. No power what-so-ever.
Suspected blown headgasket as was burning oil, so replaced that. Oil burning is solved I think, but engine still running same.
Replaced injection pump with a really good, proven unit in case pump was knackered.
Fuel system thoroughly cleaned and bled, injectors proven chucking fuel in.
I proved TDC is correct with the crankshaft damper on.
Please help, what am I missing? Im guessing its got to be some sort of timing issue, perhaps wear in the engine meant previous owner moved sprockets from what the landrover manual says? Im really concerned that it wont respond to the throttle. I thought if the timing was out, that it should still rev up?
Any ideas please before I torch the vehicle?
Cheers, Mandy
Old Oct 10, 2008 | 05:50 PM
Adz's Avatar
Adz
Default RE: 200Tdi timing problem - major headache, help needed urgently
Sounds like you're a tooth or two on the belt behind where you should be so the fuel is injected too late - is it giving white smoke while running?
Old Dec 25, 2008 | 08:16 PM
rinmud's Avatar
THE BELT BROKE????
, then unless jesus himself was with you theres a valve issue. Have the compression tested
The valve job it self not so bad, but look at the piston crowns and make sure non of them got a smiley so deep the it is venting into the crankcase. scott
Old Dec 26, 2008 | 04:33 AM
Adz's Avatar
Adz
That's not likely to happen with a Tdi... the valves are vertical and the pushrods are made out of brie, you will have to replace the pushrodsbut valve and piston damage from a broken cam belt on a Tdi is really quite rare.
Cheers,
joshrave
Nov 16, 2014 05:10 PM
RYAN3326
Sep 19, 2014 09:57 AM
discoV8I1
Feb 18, 2013 09:27 AM
tazzman
Oct 29, 2009 01:24 PM
