Defender Talk about the Land Rover Defender within.
300 tdi Double Cardan Prop conversion
Old Dec 5, 2020 | 04:13 PM
WildfireTaC's Avatar
4th Gear
Default 300 tdi Double Cardan Prop conversion
Hi. I have a Defender 90 300 TDI 1996. It was lifted by a previous owner and is eating front props. I have measured the prop angles and they are way off. I know that it is possible to fit a double cardan prop, from a Disco, I think. I'm also aware that this means that I need to change the flange into the transfer box. Does anyone know the specifics of this swap? Which Disco prop should fit etc. I don't want to spend lots of cash on a kit, just in case the angles still don't add up. I'm hoping that I can just pick up a cheap prop of the correct type to give it a try.
Old Jan 7, 2021 | 04:28 PM
hillstrubl's Avatar
Why don't you just order a custom front shaft from Tom Woods? Measure end to end and they'll build one to your specs.
4xshaft.com
bwanamich
Jul 7, 2017 10:56 AM
MiDisco2
Aug 4, 2014 04:26 PM
Raider TD5
Defender
Jun 12, 2014 06:01 AM
johnkbl
Sep 6, 2011 05:05 AM
Hybrid88
Defender
Jan 12, 2011 04:27 AM
