Defender Talk about the Land Rover Defender within.
Import Question (diesel & upgrades)
Old Jan 1, 2021 | 05:18 AM
Thomas Moeller's Avatar
4th Gear
Default Import Question (diesel & upgrades)
Hi all - apologies in advance for yet another import question!
I have a few questions I'd really appreciate any insight on:
(assuming LHD and all VINs match, original engine, etc)
- Does US customs/EPA/etc treat the import of diesels any different than gas/petrol? As in, would they consider this an additional issue for potential rejection?
- Will customs, etc reject a vehicle, even if all the #'s match up, if it has been restored in the UK? If I restore the vehicle, paint it, clean everything up, new interior, roll bar, etc - will they treat it differently than if it was straight stock/original?
Thanks
Old Jan 1, 2021 | 05:31 AM
JUKE179r's Avatar
Welcome to the forum Thomas.
Old Jan 1, 2021 | 05:58 AM
4th Gear
Thanks!
Old Jan 1, 2021 | 06:41 AM
The Deputy's Avatar
I'm kind of unsure about your question? Are you in Britain right now? And looking to make the upgrades before you bring it to the states? As far as diesel goes, mine is a diesel and was imported a few years ago.
Go to Defender Source. com and you'll find more knowledgeable folks about import questions.
Old Jan 1, 2021 | 08:19 AM
4th Gear
Yes, I'm in the UK right now (I split time between London and Bend, OR) and want to A) restore a Defender here in the UK and B) import it back to OR
So I understand an original diesel engine is (in theory) ok - but what about restoration/upgrades/cosmetic enhancements? If a slick, newly painted, Defender comes through with new tires and wheels, paint, lights, rack, etc - isn't it going to be flagged as not-original and be kicked back? Or does it really rest primariy on the chassis/vin/bulkhead, etc and original #'s all matching up?
Thanks!
Old Jan 1, 2021 | 10:49 AM
The Deputy's Avatar
From what l understand, by reading posts on Defender Source, it mainly has to do with matching numbers; engine, vin, frame, etc. Condition means little to nothing, as far as l know. Some come through in pretty rough shape and others have all of the upgrades done beforehand, since parts/modifications/facilities are more readily available there. Height may be an issue, if you are considering roof rack, have read where several folks run into problems with shipping containers being to low to accomodate extra height.
I'd join this site and ask several questions there.
https://www.defendersource.com/forums/
Good luck.
Old Jan 1, 2021 | 03:58 PM
4th Gear
Thanks!
Old Jan 8, 2021 | 09:29 AM
hillstrubl's Avatar
Its a very black and white answer, original configuration, inclusive of engine/transmission installed and body configuration (eg, don't swap to a galvy frame if it didn't originally have it and don't convert to LHD from RHD prior to import) is what is required for import. Do any changes in the states after its cleared customs. This also includes swapping to a different diesel prior to shipping.
Not if its the original type/configuration as described on the VIN
- Will customs, etc reject a vehicle, even if all the #'s match up, if it has been restored in the UK? If I restore the vehicle, paint it, clean everything up, new interior, roll bar, etc - will they treat it differently than if it was straight stock/original? It depends on what you mean by restored, changing certain integral parts (like the frame) vs fixing damage/rust are looked at differently. Its safest to import it as "straight stock/original" using your words.
Thomas Sleigh
Dec 4, 2017 03:39 PM
hilltoppersx
Other
13
May 20, 2013 09:29 PM
CarPARTsearcher
Nov 17, 2008 10:47 AM
Projekt
Oct 6, 2006 06:43 AM
traffictech870
Sep 5, 2005 04:13 AM
