Defender Talk about the Land Rover Defender within.
Defender 110 Back door cracking
Old Sep 5, 2021 | 01:37 PM
ludwig_Def110's Avatar
Default Defender 110 Back door cracking
Hello, I'm new to this forum.. I bought a DEf 110 TD5 (2004) and the back door is cracking. I have some pictures here. What would be your recommendations to fix it? thanks a lot!
interior:
Exterior:
Old Sep 5, 2021 | 07:15 PM
How big is the tire hanging on it?
Old Sep 8, 2021 | 02:24 AM
The Deputy's Avatar
Looks like someone's been in there before you. Judging by the welded piece on bottom of door below wiper motor and other signs. You could have cracks welded, then maybe reenforce area. But, the weight of tire, if over-sized, as mentioned above, may be adding to the issue.
My old 110, 1989, has a different door inner structure, so welding up cracks and reenforcing was easier than your door, l've had a 285/75 hanging from factory tire carrier for over a year now, and even after some pretty hard off roading it's holding up nicely.
​​​​​​You may have to look into a different type of tire carrier.
Old Sep 13, 2021 | 01:34 AM
Hello, thanks for your reply. I attach a picture of the wheel (120/1160), yes it's bigger than the original one I guess but the door should be able to carry the wheel, no?
otherwise it means I need to install a complete new structure to carry the wheel. I imagine I cannot do that myself.. if anyone has already done that or has info, it would be very helpful - thanks!
PatriotDefender
Feb 28, 2026 05:29 PM
_Allegedly
Jun 29, 2021 03:10 AM
Tcots
Jun 28, 2021 11:16 PM
jeanpms
Defender
Jul 1, 2020 06:12 AM
Thatcher
Jun 6, 2012 05:08 AM
