DEFENDER 2003 TD5 (problem)
Hi There,
I am new to this site, so i'm not sure if i'm in the right section to ask about a defender td5 problem, any way here goes.
I have a landrover defender 2003 td5 that is difficult to start. Problem is, sometimes when i switch on the ignition, the engine block light and the heater light fail to appear on the dash. When this happens, the defender fails to start. This only happens occasionally. My mechanic diagnosed alarm and immobilizer problem and he switched off both. Problem still persists, any ideas folk? Thanks.
I'm giving you a bump and also letting you know this site is lacking on the Defender owners so that's most likely why there is a lack in responses to your issue. I'm sure everyone that reads the title of your post is very jealous that you are lucky enough to have a diesel Defender to be having trouble with...
Good luck with your fix, hopefully someone with some knowlegde will help steer you in the right direction.
